Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Loud water cutoff noise from ice maker!
Loud pop when water cuts off to include the COLD WATER faucet on the sink next to the fridge.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Water turn on to high
Posted on Apr 02, 2009
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
May 11, 2016 | Refrigerators
I can't get a water flow from my RO faucet or from the water dispenser in the door of the fridge...also the ice maker won't work. I just replaced the 3 large filters, and no change. Just a trickle, then...
If the tank is full of water (pick it up) with 8 lbs of air then the air charge is low and little or no water will come out. Take should have 7psi air pressure when it is completely empty. Make sure all the water valves are on. If feeding RO with piercing valve make sure it is open all the way and has plenty of water pressure feeding RO. If there is no water being created then there will be no water at faucet, fridge or ice maker, assuming they are all tied into the RO.
RJ
Mar 31, 2011 | Culligan Under Sink Water Filter
The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
Water leaking from bottom of fridge. Hissing noises coming from inside. Trying to figure out how to disconnect water
There is usually a water cut off , behind the refrig , mounted on the wall , or , a cut off under the sink , connected to the cold water line ( with a small cut off valve ) .
The hissing noise , is usually associated with a hole or cracked water line . You can also try removing the ware filter , to see if the noise stops .
Would need more info , to have an idea where the water line is defective .
Nov 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice
water valve maybe leaking thru, much like a drippy faucet on a sink, if possible pull the fridge out from the wall and disconnect the plastic water line where it enters the ice maker and see if it's dripping, the water valves are pretty easy to change out and probably will cost less than 40 dollars p.s. you will need to get the ice out of the fill tube to get the water to flow into the icemaker
May 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking into the fridge. I think it is coming from the ice maker. If I turn the ice maker off inside the freezer, then the water problem is worst. So, is there a way to cut of the supplier of...
There should be a cutoff valve on the line going to the fridge. This will cutoff water dispenser, as well, if it has one. It may be behind the fridge or under the sink, or???
More help?, let me know.
May 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Insall water filter
there are lots better filters then the ones that go into the fridges install an inline filter into the water line before the fridge that way you filter both the drinking water and the ice maker any hardware store will have them usually your water supply is tapped into the cold under your kitchen sink this is a good place to put the filter if you are connected there
Apr 22, 2009 | LG LSC26905TT Side by Side Refrigerator
Installing water to ice maker under sink with universal instalation kit
attach cut off valve normally a saddle valve to the cold water line above the cold water cut off of the home, route the water line to the back of the fridge and connect it to the water valve of the ref.
the valve will be behind the compressor cover, and is normally connected with a 1/4 inch compression brass nut
Apr 11, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
