Question about Video Game Consoles & Games
Xbox 360 the problem is the games will start and after like 3 or 4 minutes the screen starts waving with different colors then eventually it freezes up
  • 3 Answers
Maybe it is your screen, try it on a different tv. And if you want *** to stop freezing don't let it heat up to much and put the big grey electric power box thing on the edge of another box so its area isn't covered as much
Posted on Jan 20, 2009
  • kcaj200 Jan 20, 2009
    i Meant it stop freezing not ***
Twister Mania start up issues
Make sure to run the Kinect setup and calibration in the Xbox 360 Dash. Move all the way to the right and select kinect settings. Run the setup and follow the instructions there. Make sure to have a Kinect setup card handy. (comes with games.) This should help with any calibration issues. If that doesn't work, try signing in with a different account, or doing an xbox live sign in test.
Jun 01, 2012 | Majesco Twister Mania X360 Kinect
Screen freeze.
two work-around methods for those consumers who are experiencing the "freeze" issue: 1) Remove or disable the HDD
or,
2) Load three different Xbox 360 games to the main title screen of each game then load Major League Baseball 2K6 on Xbox 360. All three Xbox 360 games must be completely different before loading Major League Baseball 2K6.
Dec 25, 2007 | Microsoft Xbox 360 Console
My xbox 360, has a problem i put in a new clean disk(game) into the xbox . it is a xbox 360 game and every time i put in a new clean disk the xbox says (open tray)
The XBox 360 is a wonderful video game console, however, with heavy usage, the laser (and/or other components in the drive) will eventually burn out.
The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the games will stop reading altogether and you will get an "OPEN TRAY" message when you put a disc in and close the tray. What this means is that the XBox 360 thinks that there is no disc in the system.
If you click into the following U.S. based website, you can find more information about this issue, the parts to fix it yourself and you can also send your XBox 360 to them to have it repaired:
http://store.richspsxparts.com/howtofixxb36.html
Jun 21, 2011 | Microsoft Xbox 360 Console
When playing games my xbox 360, the screen will
try this. unplug everything (power cord, av cables, wireless adapter, controllers) and take off the hard drive. dont plug anything in for about 1-2 minutes. when the time is up, put the hard drive on first then plug everything else in.
Sep 27, 2009 | Microsoft Xbox 360 Arcade
My Xbox 360 Keeps Messing Up!
Sounds like a problem with the 360's graphics chip. You might want to phone microsoft support or take it to a 360 repairer.
Aug 12, 2009 | Microsoft Xbox 360 Console
My xbox keeps freezing 20 minutes into a game of Halo Wars
Most likely your GPU has a broken solder point on the mother board.
Mar 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Xbox 360
it could be overheating, try puting a fan under the xbox 360 and then start it. also if you are using an hdtv try using just a regular tv.
Jun 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 freezing
There are two possible solutions to this issue. One the data that you downloaded either got corrupted during transfer somehow or during a resent save. You should delete all the iformation off your hard drive and start fresh. If this doesnt work try takeing off your hard drive and playing a game if it deosnt freeze you will need to either try the delete method or get a new HD.
If this doesnt solve your issue then it is very possible that your system is headed for the red rings of death. My system was fried after i had played assasins creed. It would freeze up and create this checker pattern on my back ground my system shortly after went red ring.
Dec 26, 2007 | Microsoft Xbox 360 Console
Freezing
Same problem as the 3 red light error in most cases. As far as freezing.
One red light is different. Check the error codes here.
Nov 06, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
126 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
