Question about HP Pavilion zd8000 Notebook
1 vertical line going down the notebook LCD
I have a notebook with a line going vertically down the LCD. I can change the color of the line from red to yellow to totally gone if I kind of twist the monitor from the top right corner. I have hooked it up to an external monitor and there is no line. I have also booted into safe mode and the line is still there on the notebook. I think there might be a short in the wiring somewhere, any ideas out there???
  • 1 more comment
  • vetaldj Nov 20, 2007
    Have 4 of them already: 2 green and 2 yellow... Thinking to sell it...
  • Anonymous Dec 16, 2007
    i have the same problem with my presario
    vertical lines increasing in width and numbers
    i would rather not replace screen if possible
  • cmenace27 Dec 20, 2007
    Same problem with my zd8000 PC notebook, not only 2 or 4, but about 10
    with blue, yellow, green, red. I went to CDW to ask what's the best thing to do. "Buy a new one." No more HP brand for me. Is there somekind of recall for this notebook so HP will fix this kind of problem. It's only 2.5 years that Ihave this, and there's so many problems. My Apple titanium is more than 5 years, It's on 24/7 and it's still working. Somebody wants it? Let me know.
    Problem Solver:
  • 21 Answers
I also have Toshiba satellite, it has the same problem, it is the LCD Screen, which needs to be replaced, i am not sure how new is your product, if you have any sort of warranty/coverage for your laptop. i would contact them and have them replace the LCD Screen, and i would not replace it by my self, i wrong contact can cause more damage, since it has happened to me. i hope this small info helps you.
Posted on Dec 20, 2007
    Genius:
  • 2,985 Answers
Get onto HP Tech Support Team This will mean a new screen I fear.
Posted on Jun 18, 2007
2 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: 1 vertical line going down the notebook LCD
Some of the many connections to the TFT screen panel matrix itself have have either been damaged or have decayed. These tiny connections are bonded along the edges of panel and are not viably serviceable. The most common causes are impact, stress (twisting) and condensation/moisture ingress. A replacement screen panel is needed.
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
I have vertical colored lines and cant read menu on my l32w761 envision lcd It seems to be shutting its self off also and the light blinks an orange color in place of the usual green
On all the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black line down the screen.
Good luck and take care in handling it ........
Jul 07, 2010 | Envision L32W761 32 in. LCD TV
Multi color vertical lines on my R40 monitor
this usually means that the display is broken. i'm sorry to inform that this can only be repaired by replacing the LCD module, which costs quite a lot of money (an estimated 60% of the price for a brand new laptop)
Apr 20, 2010 | IBM ThinkPad R40 2722 Notebook
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
Dec 16, 2007 | Compaq Presario 2100T Notebook
HP Pavilion zd8000 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
