Question about Gateway Computers & Internet
GATEWAY MX8715 WILL ONLY BOOT TO BIOS AND BOOT MENU SCREENS?
NEW 2GB RAM
NEW CMOS BATTERY
HARD DRIVE CHECKS OK ON ANOTHER PC
  • Michael Lucas
    Michael Lucas May 11, 2010
    additionally.... when it goes to the bios screnn.. is the system date right... If not try correctin date and time then save and restart since you changed the cmos battery.
  • Michael Lucas
    are you getting any error code beeps after you turn machine on
    Genius:
  • Gateway Master
  • 1,102 Answers
Remove the new ram
then restart if that don't get you there
let me know
Posted on Jan 20, 2009
Had a problem with my drive getting on internet installed new hard drive now can not boot up dont see drives
it sounds that you have problem in the mother board, you can hooked up your drive to other pc as slave just to ensure if it will read. if ok, then their is no problem in your hard drive also with other drive.
Nov 19, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
I have the 7 in ch sylvania notebook and i forgot my password. How can I reset it?
Remove the CMOS Battery
Detach the CMOS battery from the metal holder. Some Gateway CMOS battery holders have tabs on both sides, while with others you can lift the battery out. Press down on the tabs and the battery will pop out. Wait two minutes, then push the battery back in. This will change the CMOS settings back to default and reset the Gateway BIOS password. Replace the panel and cords. Turn on the PC and enter the BIOS menu by pressing F2 repeatedly to create a new password. To bypass creating a BIOS password, boot to Windows normally.
Then everything will be just fine.
Thanks.
May 13, 2011 | Sylvania G-Netbook
Bought a Gateway model M465-E on Ebay only to find out the bios is pass-worded so I cant load Win XP because of The infamous "no hard drive error because of the Sata Driver,and i cant get to the...
I'm sorry but I don't know how to reset your BIOS. But to get around your problem, you should be able to enter the boot menu to boot to the optical drive to install your OS.
In order to access the boot options on this notebook computer, press the F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.
To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer.
Dec 21, 2010 | Gateway M465-E Notebook
Cannot boot .
Try this. Please make sure that when you installed your CMOS battery, that you did it correctly.
Here are instructions: http://www.smartcomputing.com/Editorial/article.asp?article=articles/2004/w1510/32w10/32w10.asp
Now, if all was correct then go into the BIOS and configure your hard drive because it sounds like your hard disk isn't configured.
Most BIOS's will auto recognize the hard drive but you have to go into the BIOS and tell it to search for it and then save it by pressing F10 and save before you exit out of your BIOS.
If all else fails, replace your hard disk.
Don't forget to rate me and vote for me, thanks. Also let me know how it goes.
Mar 24, 2010 | Dell Latitude C640 Notebook
I have hp workstation xw4100 changed battery then the system. system not booting
If as I suspect you changed the CMOS battery, then you will have to set up the system BIOS again to the "Default" configuration. You will have to initialize the Hard Drive, DVD, RAM, Boot Up sequence, all again. Do this and all should be OK. You access the CMOS usually by pressing DEL, or F10, at boot time. Check your manual for exact key.
Jan 28, 2010 | HP Workstation Xw4100 PC Desktop
Ok,was starting and then shuting itself off,now it starts, all of the lights are on,but no boot and black screen. for a HP DV6000
most commonly this is called a bios loop, this is due to the fact of a currupted bios command or a damaged cpu. to eliminate bios you must disconnect battery and cmos battery usually located where memory is, cmos battery is a small cable attached to a metal disk. unattach hard drive and restart computer. after restart shut down computer and reattach battery. again start computer without hard drive. if bios screen does not appear and same sceneario occurs then your CPU is fried. If bios screen does appear and you reinstall hard drive and get same boot error then your boot sector of hard drive is gone.
Due to black screen at boot and boot loop I would say ypur cpu is gone.
Sep 27, 2009 | HP Computers & Internet
840GM will not start up all the way
Here is my flow chart.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 08, 2009 | Gateway 840GM (RB840GM) PC Desktop
Computer won't boot up after attempting to install new memory
I believe resetting the CMOS would fix this problem. To reset the CMOS, open up the computer and locate a battery similar to this one (it's on the motherboard):
Once you find it, pull it out. Leave it out for about 24 hours (one day) afterward placing the battery back into its slot on the motherboard. Now try booting up.
It should now successfully start up requesting that you make changes to the BIOS since the CMOS was just reset. Afterward you should be able to use the computer normally.
NOTE: Try resetting the CMOS with the original RAM inside the computer. The new RAM might be forcing the motherboard to send too much voltage or use an incompatible Mhz setting to support the new stick of RAM.
Let me know how it turns out and if I can do anything else to assist you.
May 15, 2009 | Dell Dimension 3000 PC Desktop
Boot Problem
Your Hard Drive is getting weak replace it with a new one , sometimes when it gets weak and get bad sectors it does not take up the OS and Boot bcoz the data written get lost so replace it or do the double check as follows
check ur hard drive is it showing u in Bios the main culprit is ur Hard Drive try re loading ur operating system by formatting ur hard drive otherwise Change ur Hard Drive it has become weak , there is a hard drive checking utility like HDDLIFE try connecting it to another desktop and scna it thru this software see the strength of the hard drive ur self download the trial version from website www.binarysense.com and let me know if it helps ,
basically if u computer boots ok and goes in bios when u press key that seems like ur whole pc is working ok incl RAM the only thing that is responsible for the operating sys is Hard disk it is where all files reside so when it crashes or get weak it doesnt give up files to boot so pc is unable to boot forward
pls do vote me if u find me helping and fixya problem
Feb 23, 2009 | Gateway 310 S PC Desktop
Computers & Internet Logo
223 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
