Question about Mitsubishi LVP-S250 Multimedia Projector
Lamp timer reset
Which 3 buttons do you press on control panel to reset timer after replacing lamp
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the < > and POWER
buttons simultaneously.
Posted on Feb 06, 2009
How to reset the lamp timer for Sony Projector vpl-px32
    Instructions
      • 1 Turn on your Sony projector after replacing the lamp.
      • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
    • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
Jul 07, 2014 | Panasonic PT-44LCX65 Television
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Hello, i would like to know if resetting the lamp timer on an LG MW60sz12 will allow you to get more time out of it?? also if it is possible, how do you reset it???
Quick answer = NO.
As projection TV lamps generally have a life somewhere between 3,000 - 6,000hrs (depending on lamp quality/type), the lamp timer is simply there to assist you in determining when the current lamp is due for replacement.
Resetting the lamp timer has no effect what so ever, on the longevity of the lamp.
The Lamp Timer Reset function is hidden within the Service menu and as such, technicians are usually the only ones who are authorised to reset the timer.
However, the following procedure has been known to reset LG lamp timers:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. While holding that button, press and hold the MUTE button on the remote.
6. Press and hold the ENTER (or OK) button on the TV front panel.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm
"If this has resloved your problem, please be kind enough to rate this solution and/or leave a testimonial"
Sep 19, 2011 | Televison & Video
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
    1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
    on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
    2. Press the MENU button on the remote controller, or the RESET button on the control panel,
    while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
    appear.
    3. Press the and select 0, and wait until the timer display is cleared.
    Feb 18, 2011 | Hitachi CP-X270 Multimedia Projector
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    I have the lamp,the tv is still not coming on. Is there something that has to be reset?
    Yes. You will have to reset the lamp hours. It should be in your owners manual.
    Copy and paste this link in your address bar if you don't have the manual:
    50VS810
    http://tv.manualsonline.com/manuals/mfg/hitachi/hitachi_projection_television_product_list.html
    I have heard that this may work on your tv
    1. Switch power ON, and press the TIMER button on the remote control transmitter, or the RESET button on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear on the lamp timer on the bottom of the screen.
    2. Press the MENU button on the remote control transmitter, or the RESET button on the control panel, while the lamp timer is displayed. The 'LAMP xxxx [] -> 0 [|] CANCEL' message will then appear.
    3. Press the [<|] and select 0, and wait until the timer display is cleared.
    Sep 09, 2009 | Hitachi 50VS810 Television
    How to reset the lamp timer count on a LG rear projection TV
    1. Press the OK or enter button on the front panel and MUTE
    button on the remote control simultaneously (About 5 seconds).
    2. Press the VOLUME (>) button.
    3. Press the OK or enter button.
    Lamp time will be reset.
    Jun 15, 2009 | LG Televison & Video
    Replacing the projection lamp
    Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
    Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Mitsubishi LVP-S250 Multimedia Projector Logo
    321 people viewed this question
    Top Mitsubishi Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
