Question about Spar SP200 Commercial Planetary Stand Mixer
Ive got a problem with my boss and supervisor at work
Whenever i come into work they start whisperiing about me behind my back for no reason alls i want to do is get on with my job im not there to make friends im there to earn a living im not interested in them whatsoever what can i do so they stop being nasty to me
    President:
  • 2,559 Answers
Not my usual help category, but here is what I would do,Just laugh out loud when they do it,When they ask what you are laughing about,Just "Oh nothing" I was just remembering what I heard about you.And don't say anything else.
I hope this helps
just be happy
You can rate this if you like.
Posted on Jan 16, 2009
Motor noise
It has been my experience with knocking kitchenaid is one of three reasons all related to the speed control of the mixer1 speed control board adjust speed screws2 speed Phase control board, needs replacing3 The motor governor behind the speed control board needs replacing
Speed board = $9.00Phase Board = $20.00Governor = $10.00Your time + one week for ordered parts asnd one hour to remove and replace.
all work is performed at the rear of the mixer and you need only a phillips #2 screwdriver, a pair of needle nose pliers, an 11/32 open end wrench (you will need this to adjust your speed control board after new install) and that's it. easy work all remove and replace. Oh! make sure that you pit some thermal paste behind the phase control board to avoid burn out.
But!!! before you buy parts and do all that, try adjusting the speed contol board first. Go here for a parts list for your model.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KV25G0X&siteCd=KAD&userType=Servicer
then go here for instructions on tuning the mixer speed.
http://www.youtube.com/watch?v=pUo_ZU5xh3o
if after you tune it you still get the knocking then use the parts list to order parts. two good parts sources are goodmans.com and mendingshed,com, they are reliable and have the parts in stock.
Aug 26, 2012 | KitchenAid KV25G0X Stand Mixer
My Ultra Series Mixer has started to make a noise so my husband opened it to inspect if there was enough grease and if the gears were worn. There was plenty of grease and the gears were fine. Now that...
the back cover is the housing that protects the speed adjustment! i THINK that this is the reason your mixer is going so slowly but im not sure, you will have to get it checked out by a kitchenaid repair centre seeing as the same thing happened to mine, they told me it was the speed adjustment.
Mar 27, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Speed control is erratic while under load
I'm going to say the first thing to check is the speed governor. You'll see it when you take the rear cap off- it's behind the plate that's mounted on three screws with springs on them. Don't take the plate off, just look behind it from the side at the shaft sticking out of the back of the motor. When you run the mixer and observe the governor you'll see that it moves back as the speed of the mixer increases and forward as the speed decreases.
The governor uses weights and springs to do its job- peek at it, you'll see how it works. If it's a little sticky then the speed will vary up and down at any setting, or it'll just run at max. speed all the time.
A little spray oil applied the the governor will clear up minor sticking problems but if it's too bad then some manual working of the governor will help it to become free and functional again. WD-40 is not the product for this job, it has little value as a lubricant because that's not what it was meant to be- it's meant to displace water. Hence the "WD"..
If you have to take the plate off the back to get to the governor you can easily set it back where it originally was by counting the number of revolutions each screw makes as it comes out. Screw them each back in the same amount and you shouldn't have to monkey around adjusting the thing.
The second thing I'd check is the brushes. Even if they aren't the problem it's good to service brushes occasionally. You want to be sure that they are clean and free in their holders. They're under the odd looking screws right in the center of each side of the motor housing. It's not all that common for brushes to cause varying speed but it can certainly happen and if it is the problem then there will likely be damage occurring. Just pull them out gently, noting the orientation, and visually inspect to see that they're clean and at least 1/4" long. Reinsert them as they came out (it's sort of important to match the curve on the face to the curve of the commutator) and be sure that they move freely all the way to the bottom of their travel. Any reluctance to reach bottom should be addressed with electric motor cleaner and a careful sliding of the brush in and out of the holder until it bottoms firmly and positively against the commutator.
The third likely source of the problem your mixer has is the little circuit board mounted above the governor. It's not meant to be user-serviceable but any appliance/stereo repair shop (if you can find one) can repair it,for you or they can replace it without too much effort. Just be sure that it's the problem before getting into it because it's sort of expensive ($35-50).
lp
Dec 26, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Hello i would like to know what kind of oil to use on a Hobart mixer d300 its a 3 speed mixer the problem im having is 3rd speed runs like 1st speed could it be the clutch that is bad thank you
d-300 and d-340 mixers dont use oil they use grease -47 can be bought @any hobart office. there are several reasons why this problem can happen. try tighning the planetary nut all the way then back off 1/4 TURN .also do the same with the top main shaft nut if that doesnt work contact me back
Nov 16, 2009 | Food Mixers
Motor is burned out
Are you sure the motor is bad?
Dec 03, 2008 | Hobart H600 Stand Mixer
My mixer started to smoke!!
The gearbox grease has separated and is starting to move (slowly) onto the motor armature area through the front bearing. Replace the grease and since it will be apart, use a lot of cloth strips (NO Q-TIPS! TOO STRINGY - LEAVES A MESS) and alcohol to clean off the motor's armature, housing area and any place you see grease slung around. It's not going to be easy, but worth it. I will try to post pictures as I am doing this right now 12/28/17 to my wife's Kitchenaid for this exact reason.The first image is the gear side of the motor bearing, where the thinning grease is moving through. The second image is a shot of the armature of the motor where the brushes touch and will smoke if grease gets that far (it does). The third image is a cleaned out armature area (brushes removed and speed switch moved)The last is the pooled oil separated and sitting just behind the gear box (where will it go if you tilt the head back?)07667273-29b4-4c89-b9b3-12896c8ef14c.jpg20171228_163751-wafg2nvpw021bpnzetjjpo05-2-2.jpg20171228_165900-wafg2nvpw021bpnzetjjpo05-2-3.jpg20171228_173846-wafg2nvpw021bpnzetjjpo05-2-4.jpg
Aug 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Hobart 450 chopper mixer
Im a hobart service tech and repaired these units often,the seal job is a pain in the ***.Everything has to be torn apart.Forget manuals hobart doesnt give them out but i can step you through it.
Jun 06, 2008 | Hobart A200 Stand Mixer
? Hobart A200 Mincer/Mixer wont work
does the motor have brushes? If so the mixer will have two removable covers on the back motor plate. If so take some light sandpaper to the part called the comutator that these carbon brushes ride on and make them shinny. If you have a newer style motor that doesnt have brushes. pull the motor cover and make sure the start switch is cleaned by sanding the contacts. If you check your wiring with a ohm/volt meter and it all checks good, well, the first question I should ask is does it hum? if not, the problems in the wiring or power switch. if it humes the problems in the comutator, start switch, capacitor or your motor is shot. unlikely for a mouse infestation. most likely wiring or switch problem.
Apr 06, 2008 | Hobart A200 Stand Mixer
What kind of bang was it ? an electrical or mechanical. The A-200 has a stator and rotor assy with a start capacitor and relay behind the back cover at the head of the unit. You can access the retaining nut for the rotor (motor) shaft by removing the small 2 inch cover and getting a wrench on the nut and spinning it by hand. The handle you mentioned with the three numbered selections are your speed settings and everything is driven through a planetary drive. Hobart A-200 have been around longer than I have (im 48) and are work horses and in my opinion, are the top of the line for mixers. Put it this way, I would take a 25 year old A-200 over a brand new Varimixer or other brand name. You can access parts manuals and break downs on Hobarts web site with model # and M/L # any other question e-mail me capt_rick1912@yahoo.com if you cant find what you are looking for I will e-mail you a wiring diagram (found behind the small gear selection cover on side) Good Luck......Rick
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Spar SP200 Commercial Planetary Stand Mixer Logo
162 people viewed this question
Top Spar Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Spar Food Mixer Expert? Answer questions, earn points and help others
