Question about Sony DAV-C770 System
Lots of problems
DVDs would get stuck when loading and never play, so we had it repaired at a local tv repair type place. It physically loads fine now but randomly does not read discs. The repair shop could not figgure it out, so they refunded most of our money. We still use it for the sound which is GREAT but have to use another dvd player.
  • russ4u Dec 08, 2007
    Disc when loading, sounds like a motor is running inside, but never picks up on the disc or plays it. Also, half the time the disc will not eject out of the receiver.
Demand Sony have a recall on this model and fix the problem!
Posted on Jul 02, 2007
SOURCE:
Why does my dvd player not play
Unit laser assembly has died . Not repairable, replacement in order.
Aug 29, 2014 | Televison & Video
Put my p-1500 in our RV. Tested with a blueray disk and worked just fine. Wanted to show wife, but it would not play any blueray. but will play standard hi-def. Any ideas?disks. Any ideas
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain lasser bean NOT reading the TOC disk +Syscon can be defective, you must go to the repair shop TV for fix it
Jul 16, 2012 | Samsung BD-P1500 Blu-Ray Player
My slot load DVD RW is not loading any CDs or DVDs.. the DVD RW was fine , i finished burning a DVD , i ejected it and i tried to insert another one to burn but it feels like there is something on the...
Well, then it may be the gear problem. I will suggest you to contact local computer service to repair the faulty part. Doing anything from your side and make the drive useless.
Feb 27, 2010 | Fujitsu AMILO PC Laptops
Ps3 problems will not load ps3 games
Sounds like your blueray drive is having issues, I would recomend calling sony ( their number is on the ps3 website) and tell them yout situation. They will either walk you through a fix or you will have to get it repaired, which means they will send you a box and you send the ps3 to them. If you have a warranty you are fine, if not you will pay approx $180.
Aug 03, 2009 | Sony Playstation 3 (PS3) Console
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Toshiba dvr will load some dvds & not others
My machine has also done this since it was new. I was just about to bring it in for repair when I thought I would try one more thing. I turned on the recorder. I put in the movie that would not play and let it load (of course it would not load). I pushed the on/off button on the recorder and held it down until the "wait" message came up on the display. After the message disappeared I turned the recorder back on. To my surprise the movie loaded and played. I tried all the other movies I had trouble with and they also played. I hope this helps. I saved my self over 200 dollars in repair bills. I was quite surprised at the lack of help from toshiba.
Dec 06, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
LG V692wk won't play DVDs
A faulty laser or the connection could be breaking!
May 17, 2008 | Televison & Video
Problem with disc drive
You didn?t mention the type of disk (something you burned or bought) or the physical condition of the disks (brand new, some scratches or lots) but if they?re commercial CDs or DVDs and you can play them in another laptop or player you should be able to play them in your laptop consistently. About the only thing I would recommend doing to a new laptop drive still in warranty would be to clean the drive using a commercial CD cleaning disk. If you still have trouble reading commercial CDs that play in other devices I would contact the manufacturer?s technical support for repair.
Nov 26, 2006 | Dell Inspiron XPS M140 Notebook
Sony DAV-C770 System Logo
57 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
