Question about Eforcity Samsung Bluetooth Headset WEP200 [OEM], Black Wireless Headset
Bluetooth Headset WEP200 keeps connecting/disconnecting
My new Bluetooth Headset WEP200 when paired with my Samsung Soul, keeps connecting then disconnecting and repeating this connection/disconnection. When placing a call via bluetooth, the connectivity stays on, then when call is ended, it reverts back to disconnecting/connecting again.
What can I do?
3 Suggested Answers
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
SOURCE: pair my samsung bluetooth to my blackberry cel phone ,
i found out that if you turn the bluetooth off and then turn it back, while turning it back on hold it until solid blue light and then try 2 connect with your blackberry i jus got mine and threw my instructions out. and i did this and it worked and if it should ask for a passcode i used 0000.
Posted on Oct 14, 2008
My blackberry bold 990 cannot discover my samsung wep200 bluetooth headset, both are on and working but whether I try and "discover" or "listen" for the bluetooth, the blackberry never finds it. Help.
Is this Blackberry a corporate Blackberry, there may be some corporate policy blocking bluetooth connection. Check with your company IT support.
Are you able to discover and connect to other Bluetooth devices?
To put the WEP200 into pairing mode, the user must ensure the headset is off then press and hold the multi-function button for eight seconds, or until the LED glows a steady blue. Samsung uses the standard "0000" as the pairing code for the device.
Hope this helps
May 18, 2014 | Samsung WEP200 Headset
Tip
Turn on your bluetooth on your phone and paired with your Samsung WEp200
1. go to your phone click on settings, connection/connectivity, then bluetooth.
2. turn-on your samsung wep200, your cellphone will automatically search/find for available connection.
3. choose your samsung bluetooth wep200.
4. if prompt you want to pair with it, click on yes or confirm.
5. then enter the headset passkey/code/pin: 0000
6. then your all set.
this is the website i used to pair and unlock my wep200 to my samsung impression.its quick and easy.
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
on Feb 04, 2010 | Cell Phones
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
I need instructions on how to pair my WEP200 to my new cell phone please.
1 Turn your bluetooth headset off. If it is on, press and hold multi-function button(for about 4 seconds) until the LED blinks twice. 2 Prepare your bluetooth enabled phone to be ready to go to search mode. 3 Turn your bluetooth headset on in pairing mode. (Press and hold the multi-function button for almost 9 seconds. The LED will be steadily LIT.) 4 Activate the Search option in your phone. You should see Samsung WEP200 in your phone's screen. Choose that and press OK 5 The phone will ask for a passkey. Press 0000. Then press OK. Give it a few seconds, your phone and bluetooth headset will be paired.
Mar 21, 2011 | Samsung WEP200 Headset
My bluetooth has been connected to another phone but I have a new phone so I want to connect it with my new phone how will I disconnect it with my old phone to my new phone ?
It is the phone, not the headset that sytore profiles. Just pair the headset with the new phone like it was never paired before. Follow instructions in usetr guide for your particular phone.
Oct 28, 2010 | Samsung Bluetooth?® WEP200 Headset...
How do put Samsung WEP200 into pairing mode?
Starting with it turned off, press and hold the Multi-Function Button for some 8 seconds, until the indicator light is steadily lit in blue, thus indicating it is in pairing mode. Only then, make the device you want to pair your headset to search for new devices. After a while, the WEP200 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset will enter the stand-by mode. There might be an indication on the other device that it is connected to a bluetooth headset too. Once they are paired to each other, all subsequent connections between them should be achieved simply by bringing they both within each other's range (with their bluetooth radios turned off, of course).
By the way, if your headseet's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Sep 28, 2010 | Samsung WEP200 Wireless Headset
I got my samsung wep200 and I am unable to connect
You must put your headset in pairing mode, prior to making your PS3 search for new devices. To do it, start with your headset turned off. Then, press and hold the MFB (Multi-Function Buttons) for some 8 seconds, until the indicator light is steadily lit in blue. Now, make your PS3 search for new devices. After a little while the WEP200 should show on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location (if this link fails, please, let me know. I will upload it to some file sharing server for you).
Hope you are able to sort your problems out soon.
Regards, Carlos
Jul 23, 2010 | Samsung WEP200 Wireless Headset
Can not pair cell phone with Bluetooth.
I neglegted to put the Bluetooth in pairing mode.
Nov 30, 2008 | Samsung Bluetooth?® WEP200 Headset...
My Sidekick don't pair this headset
I want to know they of my bluetooth Samsung WEP200 please.
Thanks
Hyacinthe AMOIKON
E-mail:amoikon@gmail.com
Apr 05, 2008 | Samsung WEP200 Headset
Not working with Samsung U600
YOu will have to put the headset in pairing mode by keeping the power button pressed till the light becomes solid blue instead of blinking. Now switch on the blue tooth of your mobile and try pairing,. it should work. passcode will be 0000
Jan 29, 2008 | Samsung WEP200 Headset
Eforcity Samsung Bluetooth Headset WEP200 [OEM], Black Wireless Headset Logo
256 people viewed this question
Top Eforcity Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Eforcity Radio Communication Expert? Answer questions, earn points and help others
