Question about Reddy Heater-30-55,000 BTU Variable
Types of fuels
I have a 35,000 btu Reddy Heater. I've had it for a number of years and it work fine. My questions is ---Do I have to use kerosene for the fuel? I thought I read that you can use type II fuels. If that is so, then what are type II fuels?
Ron
  • ronjiron Jan 19, 2009
    Thanks for trying. This information is helpful but still it is not a solution.
    Sergeant:
  • 359 Answers
YOU COULD RUN ON # 2 HEATING OIL BUT WOULD NOT RECOMMEND DIRTY AND MORE LIKELY TO GUM ALSO DOES NOT GENERATE SAME BTU PER GAL I WOULD STICK WITH KERO
Posted on Jan 17, 2009
I have a reddy 55,000 btu kerosene heater i bought used and it worked fine the first day it stayed on as long as i wanted it to now it only runs for like a minute and i don't know why it has plent of...
It could be a pressure problem, old fuel, clogged nozzle, etc. If you can furnish me with the correct model number, I will be able to help you further. Reply by using the Leave a Comment link.
Thanks
Mar 24, 2011 | Reddy Heater-30-55,000 BTU Variable
Problem: Will not spray fuel through nozze. Lines are not clogged. Have cheecked spark plug. It is firing. Special note: It is Series 35,000 Reddy Heater.
You can try adjusting the pump pressures, but it does sound more like the pump went out on you. Have you checked to see that the shaft to the pump is turning? I am not sure how that mates up with the motor be it a set screw, or coupling, but would check it over the pumps are generally not an issue.
Dec 20, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heater comes on fine runs 5 to 10 minutes and quits. sometimes it doesn't run that long
Are you using old fuel from last year? If so, drain/clean tank. Check/replace fuel filter. Refuel with fresh fuel & test again.
Dec 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
If my heaterr was tested for all fuels , then why dont it work?
no please don't mix. disaster waiting to happen. You will be changing flash point. Do not do it.If kerosene hard to come by ,see if you know someone in aviation that can give you sumped jet fuel.
Jan 05, 2010 | Reddy Heater-30-55,000 BTU Variable
Do i need to replace filter if i have been using kerosene and want to switch to diesel
No, the kerosene is number 1 fuel oil and Diesel is number 2. No.2 is a heavier fuel with more BTU's than the kerosene. After you have burned the diesel for awhile, you may want to change the filter. If you have trouble getting the diesel to burn, mix it with 25% kerosene and it will flow and go through the nozzle easier
Jan 04, 2010 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater Doesn't fully ignite
First thing I would do is clean all of your air and fuel filters and check your lines for breaks. A lot of times they will do that if your not getting enough air to fuel mix. If it continues after that it's the CAD/ flame sensor which you can get from MR. Heater for 3 bucks they are all basically the same and I know reddy heater wants 18 for the same thing.
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
135 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
