CMOS NOT SAVING IN MY MOTHERBOARD
I have amother board. its chipset is STPC Atlas (516BGA). in that problem is whenever i restart the system after restarting my system date & time changed.means what cmos is not saving. So pls Giv me solution of the above problem.
  • rakkhatal_19 Jan 16, 2009
    I have amother board. its chipset is STPC Atlas (516BGA). in that problem is whenever i restart the system after restarting my system date & time changed.means what cmos is not saving. So pls Giv me solution of the above problem.& i also replaced the cmos battery.
  • rakkhatal_19 Jan 17, 2009
  • 98 Answers
It seems your CMOS battery has failed. You should replace it with the new one. Ask at your local shop for info about CMOS battery you need.
Posted on Jan 16, 2009
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Will not boot to bios or beep
BIOS is a software program that controls basic functions in your computer, such as boot order, keyboard control and how your processor interacts with memory cards. If you get an "NTLDR Is Missing" error, inspect your BIOS utility to make sure your computer is booting up from the right place.
Cmos is located in BIOS
Restart your computer
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
if you need to change any of the settings using the arrow keys you can load failsafe or optimised defaults
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
hope this helps you
Feb 08, 2012 | ASUS ALi Chipset A7A266 (A7A226)...
I brought my intel pc on 23/07/2007, core2 duo processor& dg965ry chipset mother board. Now my system get restarted in every hour, retailer advise me to replace the motherboard, i wish to know whether...
I brought my intel pc on 03/09/2007, core2 duo processor& dg965ry chipset mother board. Now my system get is not booting and showing some EB Display on the right end corner. plz find me the Solution...
Jan 04, 2011 | Intel DG965RY Motherboard
Pc restarts & display "System has recovered from serious error"
If you have *********** board manual still then try and clear the CMOS memory,
turn the computer off
remove the power lead from the back
take the side off
remove the cmos battery
move the cmos jumper from pins 1 and 2 to pin 2 and 3 and the back to pins 1 and 2
replace the battery
put the side on
replug in the power lead
boot the computer
if that doesn't work then try to fix the bios.
here are instructions for that:
http://support.intel.com/support/motherboards/desktop/sb/CS-023360.htm
and here is a link to the .bio file for you:
http://downloadcenter.intel.com/download.aspx?url=/10140/eng/EV0482P.BIO&DwnldId=10140&ProductID=1673&lang=eng
Feb 18, 2009 | Intel D915GAV Motherboard
Bios gets reset whenever i turn on my pc
The battery on the mother board need to be replaced.
Dec 29, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Hi melnavz,
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Shuts down 5 to 10 sec after start up
first of all get to the jumper next to the cmos battery in the main board try to change its position for some seconds while power is off this way you will clear cmos. start computer go to bios (hit delete on start up) and save changes.
hit delete on start up and load system defaults then exit saving changes.
chek the board position sometimes if its bottom was in contact with any metal of the pc case then this could cause it to restart (this could damage ur system too!)
Nov 13, 2007 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Loses CMOS settings
there is a jumper near the board cmos battery. try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear.
turn the pc on hit delete to enter setup and load system defaults then exit saving configuration.
Nov 11, 2007 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
450 people viewed this question
David Payne
David Payne
