Question about Alesis RA-150 Amplifier
Mmt-8 alesis squencer
It loosing memories after i record something i close it when i open it again evertything that i record gone
    Genius:
  • 1,175 Answers
HI...
Replace the memory battery.
Posted on Jan 18, 2009
What are the features of Alesis Nitro drum set?
The Alesis Nitro is the best-selling electronic drum kit . It is a complete 8-piece drum kit featuring tom pads, a dual-zone snare drum, cymbals, an aluminium mounting rack, and a powerful electronic drum module that gives you hundreds of percussion sounds and 60 built-in tracks.
From the last few years alesis nitro review is very good. It have a features like :
1) It had a Dynamic, comfortable pads for great feel and natural response.
2) It had a
8" high-quality rubber drum pads (dual-zone snare, three single-zone toms)
3) It had
60 built-in play-along tracks, sequencer, metronome, and performance recorder
Sep 11, 2017 | The Office Equipment & Supplies
How to hook up the wires of Mackie CR-1604 mixer, to Alesis ADAT xt20 recorder
If memory serves correct you have rca and outs, 8 each. Using rca to 1/4" cords work the best. Connect each of your cords from the "in" on the alesis to the channel access 1 through 8 I believe to the first click. Run the "outs" from your alesis to channels 9 through 16. Use 9 through 16 as playback and 1 through 8 for instruments. This is one good way of doing it with our limited gear. Good luck!
Jun 01, 2014 | Mackie Cr 1604 16 Channel Mixer
I have alesis 10|2 interface,i tried downloading the suitable driver,i had it working in fl studio 11,but when i turned on my laptop and went into flstudio11 to try and record,it doesnt work,when i pl
Did you get the windows 8 version of the driver? If so uninstall the driver and reinstall it. If not, then you'll have to get a windows 8 driver.
Apr 19, 2014 | Alesis Computers & Internet
Alesis masterlink ml-9600 pauses during recording
  • alesis support
  • from what i can see about the device firmware update is probably what it needs...
  • Alesis Update
  • there address and phone is in top link.....sorry cant get much information from the company with out an account...
Nov 11, 2013 | Alesis MasterLink ML-9600
Camtasia Studio 8 Only Opens Once per Start-up
what u need to do is if you have windows press ctrl shift esc and the task manager should pop up go to processes then on the list you would see Camtasia studio right click and select end process or if u see the name more than once end the process of them all the reason you have to do this is because for some reason the first time you open and close it it dos not actually completely close witch then gets in a glitchy state to where you can not open in again but by ending the process u should be able to open it again
Jun 17, 2013 | TechSmith Camtasia Studio for PC
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
You've recorded a track. You hit Stop. You want to capture more of the conversation in the room, so you FORGET to hit New Track, and instead push the record button. Which resets the already-recorded...
Yes, it's gone.
This is the one glaring fault with the 9600, if you select a previously-recorded track, and hit 'record', and then 'play', there's no failsafe, or 'are you sure?' prompt to remind you that there's already content within that track.
If you select the track, and ONLY hit 'record', putting the machine into record standby, but don't hit 'play' to start recording, your previous content is saved when you hit 'stop' - record standby doesn't overwrite anything.
Dec 08, 2010 | Alesis MasterLink ML-9600
I want to copy LP's to Alesis ml-9600
You will need a phono preamp or use the tape out from a receiver/amp.
Nov 12, 2008 | Alesis MasterLink ML-9600
Alesis RA-150 Amplifier Logo
139 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
