Question about Tally T8006 Laser Printer
Faint mirror image when printing
Hi, I have a Tally T8006 and when I print anything the original print seems to be copied on the next sheet like a faint mirror image, can anyone give me an idea what may be causing this and how I may fix it? Thanks BigBoyUK
  • Ian Chaplin Jun 19, 2007
    Thanks, I have just seen the price of a new fuser so as I only paid £99 for the printer I think it will be going back to the ebay seller where I got it from!
    Thanks for your help.
  • 84 Answers
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
Posted on Jun 19, 2007
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
Sharp copier, not producing clean copies
Check the fuser roller if it still has faint prints on the roller then your getting a shadow image in your prints,. Could be a bad fuser roller replace it
Mar 24, 2010 | Sharp Office Equipment & Supplies
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
All of a sudden my spread sheet is being printed as a mirror image.
The next time you go to print something, select "Preferences" when the first window opens. On the Advanced tab, under Printer Features look for "Mirror Image". Make sure it is set to "Off". If not click "On" and change the drop down to "Off".
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Printing a mirror image
I called a Canon rep and the printer does not have that option on it.
Feb 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Best regards,
Feb 08, 2008 | Tally T8006 Laser Printer
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Can't Print with Tally T8006 Laser
can u print anything else?, if don´t disconnect the printer, reinstall drivers and connect again.
Oct 18, 2006 | Tally T8006 Laser Printer
Tally T8006 Laser Printer Logo
144 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
