Question about LG CU500 Cellular Phone
When closed, the outside screen does not light up.
When I open the phone, all is fine. When closed I only get a very dim light in the window which actually only shows in the dark. No info shows in window. New phone purchased in Aug 08.
Thanks for any help.
Took battery out and turned back on. I guess maybe should power up and down every once in a while, it might reset things. Ended up no big deal. thanks.
Posted on Jan 17, 2009
SOURCE:
I cant tell from looking at the owners manual, which fuse is linked to the drivers side window. Mine is not going up or down.
All the windows are fused by just one fuse, if it goes all the windows stop working. You either have a defective driver door control switch or the window regulator motor is defective. I would think the motor inside the door that lifts the window is the issue here. You can verify it (window motor defective) by doing this simple test, at night open the door and leave it open, operate the driver door window switch and watch the interior lights (dome light in particular), they will dim just very slightly if the motor is defective, if they do not dim then the switch is likely the cause.
Jun 01, 2016 | 2004 Ford Freestar
Brighten laptop screen
this prob is may be with your screen wire it may be short
Sep 03, 2013 | HP Computers & Internet
My motorola v557 cell phone doesn't light up. how
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 12, 2010 | Motorola Mobility V557 Cellular Phone
Outdoor photos are all over exposed and white. Video works fine.
set ur screen first .click one image 1st load on ur pc. see the screen and pc screen then set ur screen brightness and contrast of ur camera
Jun 17, 2009 | Mitsuba DV505 Digital Camera
Screen is dim on the home screen
loose flex cable,happens when phone gets dropped ,open it ,reinstall ribbon cable,turn on,check,close it back up.
Feb 03, 2009 | Motorola Mobility RAZR V3
Dark screen
go to your dispaly setings and check on the contrast and ilumination, if they are low, increase them and the screen will be bright
May 16, 2008 | Nokia 6133 Cellular Phone
Dell Laptop Screen goes Dim After 5-10 minutes
plase use another RAM in the same machine if the sam e problem will arise..its u r mother board prblem otherwise u r ram problem
Jan 19, 2008 | Computers & Internet
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Black Outside Screen
When you are looking at the RAZR, push the button on the right hand side. This should light up your outside screen to see the time when the screen is dark. Have you tried this?
Dec 23, 2006 | Motorola Mobility RAZR V3
Motorola RAZR V3 Cellular Phone
Ok so when I close my phone I still see the time and my background picture but no light immanates (hope I spelled that right)from the screen if thats what your saying that's normal. Now as far as the inside screen if you dropped it the connection that lets the phone know it's closed may be jarred lose and offset (not sayin u dropped it)although you say it dims. When you close your phone the inside screen should turn white and then turn off just barely have your phone open to check, if it does this then the connection is working. And you need another opinion.
Dec 07, 2006 | Motorola Mobility RAZR V3
LG CU500 Cellular Phone Logo
26 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
MERCY GATHUA
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
