Question about Delphi Roady XT XM Radio Receiver
Roady XT periodic errors
My Delphi Roady XT will periodically stop working. Usually an error of either "Antenna", "No Signal", or "Loading". Most often it cycles through several of the error messages. It has recently stopped working for long periods of time (a day or two) before magically working again. Its getting annoying. Any ideas? I'd hate to go buy a new antenna if that isn't going to help.
  • 5 more comments
  • mikeneve Jul 22, 2008
    Both of My Roady XTs will say antenna and stop working and then load and work for a few minutes and then it'll start all over again and it's really frustrating when all I want is to listen to the radio. I think it's time to get a new radio and saty away from this type. If anyone has solutions please post, Thanks.
  • Mary Downes Aug 11, 2008
    We have the same problem, it started in the car and at first I thought it was a shorted antenna wire but now it's happening in the house too. It'll be playing fine for several minutes then all of a sudden it loses the signal and comes up with "ANTENNA" or sometimes "NO SIGNAL". We found that if we press it really ******* the right side onto the cradle the signal returns, but having to hold it like that isn't a fix. We've had the Roady for just a year and a 1/2, it was a birthday present for my husband, and I'm very sorry for the money wasted on this cheap product.
  • Anonymous Sep 16, 2008
    My wifes roadie xt just recently started having the same exact problem (antenna, no signal). She said it will happen every couple of days, and the error can last anywhere from a couple minutes, to a day or 2. after hearing of this, I obviously thought there was something wrong with the antenna or wire leading to it, so i inspected the entire length of the wire and found it to be in perfect condition. Just as somebody else had suggested, i suppose it is time to get a new receiver. thanks for the info, all.
  • Anonymous Oct 07, 2008
    Same problem here ... bummer
  • jh112 Oct 22, 2008
    Exact same problem here. I thought it was my antennae wire too. If I leave mine just hanging from the mounting bracket in my car it works fine. As soon as I mount it--it starts all over again. I guess I'm in the market for a new XM receiver.
  • Robo49 Dec 18, 2008
    Well I have a dock at home, one in the van and a boom box at work. I take it from home to van to work and bak hme again everyday. Some days I'm at home listening and then go shopping etc. so it has handled a lot of movement.....now it continually goes in and out. I'm getting Direct TV this week so no longer will need a dock at home. Guess I will buy a new one for the van/work.
  • BobJohnson Oct 06, 2013
    In my Roady 2, the problem started with the base in the house, then the one in the car. For a few months, if I pushed down hard, could get a good connection, but after a while, even that didn't work (not even rubber-banding the radio to the base to maintain pressure). So I opened up the unit (pry out the two rubber nubs on the back and use a small Torx driver to remove the two screws) and found with a stong magnifying glass that the problem was that the solder between the three pins from the antenna connector to the PC board had cracked - that's why pushing down hard worked for a while; it pushed the connectors into the PC board and closed the cracks. So I resolderred the three pins to the PC board (fine tip soldering iron, just held it against each pin to reflow the solder) and it's worked perfectly for weeks.
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Posted on Jul 28, 2008
SOURCE:
How to repair antenna connection on delphi roady
Copper czge? You mean the plug that goes into the base unit? Or just the antenna connection on the roady?
May 17, 2014 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
I have enjoyed my radio for about 2 years. For about two weeks I get the message"loading" on my radio. It does not happen all the time, but it seems like it is happening more frequently. It will...
Just a few weeks ago Sirius XM changed there channels. That might have been one problem. But it shouldn't be loading all the time. It might be losing the channels and have to reload the channels.
May 26, 2011 | Delphi Roady XT XM Radio Receiver
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
Antenna message on roady display
I have the same problem. I hooked it up to a different antenna and it works
Nov 04, 2008 | Delphi Roady XT XM Radio Receiver
Roady XT Problem
Sounds like a software glitch, you should try
I need to get my Delphi XM Roady, Roady2, or RoadyXT repaired, where can I take it?
At this time, Delphi does not currently have an authorized repair center. If you are within your one-year warranty period, please contact the Delphi Warranty Center at 1.877.GO.DELPHI (1.877.463.3574). Hope this is helpful
Mar 11, 2008 | Delphi Roady XT XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
934 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Larry Tezekjian
Larry Tezekjian
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
