I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
Posted on Jan 17, 2009
I have a propane PRO 100 Reddy Heater. It will ignite, but when the switch is released or the flame goes out
sounds like maybe a bad thermocouppler or the thermocouple needs cleaned....
try that repost if anymore problems.... the thermocoupler will be next to the flame usually a copper piece lightly clean with some sand paper...
Jan 08, 2011 | Reddy Heating & Cooling
My heater won't stay running
if you get heat when it runs and then it shuts downs you need to clean your flame rod or replace the thermocouple if its a pilot lit furnace
Feb 06, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I lights when I hold the button down and goes off when I release it. It is a model for propane and says model 100,104,106,110. reddy heater
You need to hold the button down for 15 to 30 seconds before it will stay lit. If you are doing that, the thermocouple is bad. They are cheap and can be found at any hardware store.
Jan 27, 2010 | Reddy HD30 Heater
Fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Jan 14, 2010 | Desa International Reddy Heater R40 40,000...
Reddy Heater will not stay lit
Thermocouple it going bad had same problem, you Should replace it.
Jan 03, 2010 | Reddy Portable Forced Air Propane Heater...
I have a 125 propane heater it will not say lit. the propane is full. its been working great till now. is there something i can do to clean it or something to make it stay lit?
I'm not that familar with the Reddy heaters but there should be something that senses the flame. It probably needs cleaning. Look in the area where the flame is. I may be a small metal rod with a wire attached to it. This type will be located so that it is in the flame. You can clean it with some steel wool. I don't think it would have UV or cad cell type sensor which see the flame and wouldn't be located in the flame but would be close enough to "see" it. This type could just be wiped off with a cloth. Hope this helps.
Dec 30, 2009 | Reddy Portable Forced Air Propane Heater...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't stay lit..
I contacted ReddyParts.com and talked with their support department (866-883-9312). They instantly stated "your thermal coupler is bad". They had 1 in stock for 19.99 + shipping. I ordered it and plan to have it installed and tested by next weekend. The model I have is Reddy Heater Propane 35k to 55k (RLP55V).
Dec 12, 2008 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
