Question about Maytag MTF2195AE Top Freezer Refrigerator
Concaved out freezer door
One year old fridge started to accumulate ice inside top front of freezer. Investigated and found manufacture defect. Door is concaved out in the top center. Gasket allows air.
  • Anonymous Mar 16, 2014
    ice accumulates along door of freezer and back panel
  • 27 Answers
If concave is severe you will have to replace door. You can try to alleviate a slight gap by using a hairdryer and blowing hot air on the gasket in the area of the gap....move the dryer in up and down motions and the gasket will expand! Just make sure that there is no ice pressing against the door inner first! Oshie
Posted on Jun 26, 2007
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Thick brown liquid at leg of of refrigerator
the thick brown liquid is decomposing moss, from the condensate inside the unit finding a way out.(think of it as the same stuff you get around a shower tray)clean out the fridge using clorine bleach and dry thoroughly....leave the door open for the clorine to gas off otherwise it will taint the food.when the smell has gone then close door and switch on.(some people use milton fluid,but clorine kills all known germs....)
Jul 16, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Our N369B fridge freezer has a large amount of ice clinging to the upper back of the fridge how do we stop this happening?
Your freezer door is not closing properly. if it is not on wheels then make sure the bottom nut that also holds the front wheels or slider in place is tight. Also maybe have the seals replaced and check door alignment on both doors. You will of course have to defrost the freezer.
Oct 27, 2009 | Fisher and Paykel Active Smart E522B...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Frost in Freezer, front of shelves
Sometimes enough ice will accumulate at the front of the shelves to actually block the door from closing completely. Are you in and out of the freezer often? Moist air that hits the frozen shelf surface will accumulate at the front of the shelves first because that's where it hits first. Check that the freezer is level and plumb not on a "twist". If it is sometimes the door will not seat properly and therefore leave a gap for air to get in. Take a dollar bill and place it in the door seal surface. Close the door and try to slide the bill out from between the door frame and the seal. Do this in several places around the door. If it comes out with little or no friction you may have found your problem. Finally, completely defrost the freezer shelves after removing all the food. Don't poke or dig with an ice pick or screwdriver or you will poke a hole in the tubes and ruin the freezer. You can speed things up with some hot water in a pan placed inside the freezer. Be ready with towels or pans to collect water. Good luck!
Jun 26, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Maytag MTF2195AE Top Freezer Refrigerator Logo
90 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
