Question about Toshiba DKT2020SD Phone
Need to set up DND
How can I manually turn on/off DND or program one of the 20 buttons to be the DND?
  • 45 Answers
You would have to have know the type of telephone system.
go into prog 39 and put code 498 on that port(000*015)
info@ameritelnj.com
Tony
Posted on Apr 03, 2009
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How do I set the time on a Panasonic KX-T7667
You should download the manual from here or check the steps below: Panasonic KX T7667 User Manual
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Aug 09, 2012 | Panasonic Lands Phones
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
When i press the program button and FWD/DND buttons nothing happens
You have to set the button up first. You can press the FWD button (or press INTERCOM and dial *710) then x (500 or 165 for your voice mail) #, where x is 2 for all calls, 3 for busy, 4 for no answer and 5 for busy/no answer. That will set the FWD for calls. To set DND, dial *7101. Once you set those codes, your FWD/DND will toggle between the 3 steps of OFF/DND/FORWARD.
*7100 cancels the button. These are the codes for All calls. There are 711 and 712 codes for internal and outside calls if you need to split them. Also, the No Answer and busy timer can be adjusted by the *713yy command where yy is the number of seconds. A good number is *71324 which gives you about 4 rings.
This is explained in you phone system Operating Manual (OM) under Call Forward and Do Not Disturb.
Carl
Aug 24, 2011 | Panasonic KX-T7630 Corded Phone
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
How do i turn off the DND on my KT-X7331 desk phone
Typically this is controlled by the status of the FWD/DND button and indicated by the button light.
button light off: Forward and Do Not Disturb off
button light blinking red: Forward on
button light solid on: Do Not Disturb on
The functionality of this button can be customized by the phone system installer. If the method outlined above does not work the status and activation of this feature can be accessed through the staion programminng. To use station programming press <program> then scroll through the features using the LCD screen navigation keys or enter the specific program number. To program FWD/DND the program number is 50.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Want to turn the DND off
Typically DND is turned on and off by pressing the FWD/DND button. There are three status conditions for this button indicated by the button light.
button light off: both features off(Forwarding and Do Not Disturb)
button light blinking red: Forwarding on
button light solid red: Do Not Disturb on
The functionality of this button can be customized by the phone system installer to work differently than outlined above. Station features can also be accessed through station programming using the LCD screen by pressing the button then either scrolling through the features using the LCD screen navigation keys or entering the specific program number as in 50 for FWD/DND programming.
Dec 08, 2010 | Panasonic KX-T7731 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Oct 01, 2008 | Panasonic KX-T7633 Corded Phone
Incom calls
check the user manual under "clearing setting" athis should clear any programmed settings, also check "call forwarding and DND ( this the FWD/DND button you refer to ) here is the link to the manual http://www.westlakecom.com/KXT7700-User-Guide.pdf
Dec 01, 2007 | Panasonic KX-T7730 Corded Phone
Toshiba DKT2020SD Phone Logo
149 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
