I had problem with my computer that use window vista about microphone that didn't work properly but in window xp it work normal and the sound when i spoke so loud to out and in window vista not loud. what should i do? can tell me to this problem?
  • 98 Answers
  1. Right click Volume icon next to clock in lower right corner of the screen.
  2. Click Recording Devices.
  3. Select Microphone from the list.
  4. Click Properties.
  5. Pick Levels tab.
  6. Move the slider as desired.
  7. Click OK twice.
Posted on Jan 16, 2009
  • Nikola Malesevic
    Nikola Malesevic Jan 19, 2009
    Just wanted to know if this solution solved your problem.
    If so, please update your ratings.
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
Does the emachines e525 have an internal microphone
high definition audio device not plugged in
Nov 12, 2011 | Computers & Internet
I am unablem to use the mic for the internet chat!!!!
First of all find the latest version of the audio driver which is compatible to vista, as most of the drivers that are shipped with sound-card or motherboard cd contain drivers which have support for only until windows Xp.
So it is strongly recommended to download the latest audio driver from the internet for your sound-card or on board audio chipset. Install the vista compatible audio driver (sound driver) for your sound-card or motherboard audio. After this re-start your computer. Half of the work is done.
Now plug in the microphone in your sound-card / motherboard audio pin (generally pink in color for microphone).
After this go to control panel > sound and audio device settings. Check whether the microphone is detected by Vista or not. If not, check whether you have selected the frontal microphone or rear, as vista recognizes them separately unlike windows Xp. Correct the configuration of front/rear mic if needed.
Nov 16, 2010 | Computers & Internet
I have installed my Matrix webcam but the
Skype have a very good audio set up to follow -on how to set up your mic from the control panel
Windows XP:
The only thing I would add is to restart your computer before configuring the mic to your chat program
Jun 20, 2010 | Computers & Internet
Hi, I want to download drivers for the microphone. Lenovo 3000 N200 modèle 0769-A43 , thanks
There's no such thing as "microphone driver"... To make the microphone work, you'll need a driver for the audio/sound card and/or a webcam.
Audio device:
For Windows Vista - HERE
For Windows XP - HERE
For Windows XP/Vista - HERE
Mar 15, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
I have a normal dell pc and am using windows vista.. I recently purchased a audix om2 microphone. I also purchased an adapter that plugs right into my microphone jack on my pc.. I have plugged this into my...
Have you checked if the option for the Microphone is selected? Go to the Sound settings and then click Option/s. Make sure Microphone or Mic is selected.
Jan 06, 2010 | Audix OM2 Professional Microphone
Vista Ultimate -Microphone on Cyber Acoustics Headset not working
Here you go go
their its the dell drivers page for Vista, download the drivers their for the microphone and you can
also download things you might need for the computer
Hoped this really Helped,
Dec 24, 2008 | Microsoft Windows Vista Ultimate Edition
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Feb 25, 2008 | Logitech Webcam
Microphone is working.
dear bhaveshdave,
you have to first install the sound drivers compatible with windows vista. you can download them in the following link:
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
