Question about Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwasher won't drain
My dishwasher wontdrain. Ihave checked the filters it's only 14 months old. Wht ould be the prolem?
  • 10,865 Answers
The problem is probably a simple one to fix. Remove the panel on the lower front of the dishwasher and disconnect the drain hose. Check in the hose for debris, like pieces of a broken plate.
Next remove the pump and look inside of it for pieces of debris. I am betting that you will find a chunk of glass or bone in the little pump. REassemble everything and your dishwasher should be fine.
Posted on Feb 07, 2009
My Kenmore dishwasher wontdrain #665.17002400
did u check drain hose it might be plugged. also some people put in new disposal. disposals come with knock out u need to remov it or it camt drain
Jan 26, 2015 | Kenmore Dishwashers
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
Maytag dishwasher MDBH985AWS1 won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 19, 2011 | Maytag Dishwasher
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 07, 2011 | Dishwashers
Water in dishwasher, will not pump out. Noise when machine is turned on
Hi
Daniel
Mar 25, 2011 | Tricity Bendix 24 in. BDW53 Free-standing...
IT STOPPED IN MID CYCLE AND IS FULL OF WATER. iT NEVER REALLY DRIED THE DISCHES AND IT IS 14 MONTHS OLD
It can be fault in the program controller unit, fault in the drain pump/drain valve section.
You will need help to first of all drain off the water by unplugging the drain , then check the main board for the cycle operation, check the pump and the door switch and the sensors.
Feb 07, 2011 | Kenmore Dishwashers
Water will not drain out
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Not Working at All
Check wire nutted connections where power cord connects underneath.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
124 people viewed this question
Top Tappan Dishwashers Experts
Ronald Rissel
Melissa Martin
Melissa Martin
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
