Question about HP Compaq ProLiant DL380 G4 Server
HP DL380 G4 Video resolution
Hi Guys,
I have a DL380 G4 with an imbedded Rage XL video adapter, I am running server 2008 Standard 64 bit and the best resolution I can get is 1024x768. Is there anyway to increase this?
Thanks,
Don
To increase the resolution on a DL380 G4 try this.
So here is what I have done.
- Download x64.zip file from ftp://ftp.supermicro.com/driver/VGA/ATI/RageXL/x64.zip
- Run/Expand the zip to same directory
- DO NOT run the setup file or you will get the error message,
"Setup will only run in Administrator mode. Setup is aborting"
- Launch Device Mgr
- Expand the Video Driver and update Standard Video Drive. Point to directory x64.
- The server will need to reboot
- Display settings can be raised from 1024x786(16bit) to 1280x1024(32bit)
Note: 1600x1200 (16bit) is available but does not work on mine. If you set it to this setting and the video does not come back, connect up a higher resolution monitor and set it back.
Posted on Jan 24, 2012
  • 44 Answers
I agree with fehknt.
Posted on Nov 25, 2011
  • 32 Answers
I'm afraid that the server video cards on these are pretty poor, the only way to improve this is to add a PCI video card (I added a cheap MX440 to a server I run to get around this). If your PCI slots are all filled up then I'm afraid there's really nothing you can do.
You could TRY to decrease the color bit depth, and see if that helps. Often the video drivers don't support detecting when a higher resolution is possible due to a lower bit depth, or the cards don't actually use less storage for them. (the problem is a lack of RAM on the card to hold a full screen full of pixels at a higher resolution.)
Posted on Jan 18, 2009
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
Aug 11, 2012 | HP Compaq ProLiant DL380 G4 Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
May 18, 2012 | HP Compaq ProLiant DL380 G2 Server
Hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
May 07, 2012 | HP Compaq ProLiant DL380 G4 Server
Is HP ML 110 server compatible with 64-bit Windows 2008 R2 server?
Yes it should be.. Well the main important part is that you have a 64Bit processor installed on it.
So just make sure your processor is 64Bit then it will run 2008
Regards,
Jul 25, 2011 | HP Compaq ProLiant ML110 G4 Server
USE441A02R-ProLiant DL380 G4 HP NC7782 Gigabit Server Adapter IF we select 1000MBS it failes to connect n/w, But we select 100 MBS it will resolve
I have the same problem and have seen two possible options for resolution...try updating the NIC's firmware and it could be a motherboard problem that needs to be replaced by hp. If either of the options provides the solution, let me know. I'm in the midst of it. (I've tried updating the drivers, swapping network cables, even feeding the NIC a known connection that gives 1Gbps.)
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=407733&prodTypeId=329290&prodSeriesId=407731&swLang=8&taskId=135&swEnvOID=1005#2995
Aug 13, 2010 | HP Compaq ProLiant DL380 G4 Server
Hp DL 380 G4 no display on screen, all the status lights are green
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
Dec 03, 2009 | HP Compaq ProLiant DL380 G4 Server
No display on DL380 g4
This can be caused by a processor / VRM issue or even a system board fail. Try dropping to a single proc and VRM and swap test with the others.
May 01, 2009 | HP Compaq ProLiant DL380 G4 Server
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
2,314 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
