Question about Logitech Quickcam IM 961361-0403 Webcam
I need the drivers for webcam700 cefc tested to supply with fcpp standard.
  • 98 Answers
You can download drivers here. You'll have to choose your camera model.
Posted on Jan 16, 2009
Cefc cp
Depending on how old your WD hard drive may be....it's either 12VDC
or 5VDC - voltage can be checked on older drives the use 4 pin plugs
(usually white and referred to as Modulex plugs). Newer WD drives
may use SATA cables to power. Most drives indicate all this info on
their labels (top-face of drive). Good Luck.
Apr 18, 2014 | Western Digital Computers & Internet
Cefc d33193
Often when this happens, the drive was removed without "Safely Remove Hardware" . Try different computers (Operating Systems) and when recognized, Use the "Safely Remove Hardware" key. Then try it on your laptop.
Oct 12, 2013 | Computers & Internet
Cefc d33193
the partion was rendered unreadable you can use harddisk low level format tool to format the device
Oct 11, 2013 | GPS
Trying to sell my 2005 Rendezvous and possible buyer is questioning the 3.4 litre v6 intake manifold gasket problems once about 100,000 kilometers mine is at 90000km and I have extended warranty, Is the...
the intake gasket problems are on the older versions of the 3.4 litre.spray carb cleaner around the intake and if the idle speed does not increase ,there is no leak.
Oct 28, 2010 | 2005 Buick Rendezvous
Toshiba CZ32V51
two things can be affected, a tuner if you were using out door
the other one is the power supply. the tv sensed a high voltage (surge)
firstly you need to repair a supply, check the following.
i rectifier diodes at the power supply
ii power trasistor, driver trasistors diodes, zener diodes
ii fusable resistor near a power transistor
after the tv will come on ----if they will be light on the tube then test a tuner, by putting in signal.
Jul 08, 2008 | Toshiba CZ32V51 32" TV
W2646 crapped out
Some eMachines computers (like many from Dell) use a non-standard pin out for their power supplies, so if you try a standard ATX power supply it may not function.
However, in my experience it IS likely to be the motherboard. Luckly I have been able to replace quite a few of the eMachines mobos with a standard mATX mobo, since you can probably remove the IO plate. You'd certainly want to replace the power supply when doing so.
Jan 25, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
How to test the voltage regulator
The only test you can do on this regulator is to see if is shorted or not,this is a switching regulator ,that means is design to be use in a switching power supply witch turns the transistor on and off constanly and uses feedback to stay regulated,the B+ they use in the collector is around 150 volts,an small square wave is applied to the base ,it gets amplifies and energizes the primary side of the transformer to generate all the supplies ,one of this supplies provides the feed back.I hope I have given you the more than the information you needed.
Oct 16, 2006 | Sanyo DS27510 27" TV
Logitech Quickcam IM 961361-0403 Webcam Logo
64 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
