Question about RCA Audio Players & Recorders
My mp3 is not charging
My rra mp3 while charging had marked battery full later in went into initializing, now i am not getting any connection battery is not charging
I found that Holding the power button for about 6-10 seconds will force it to turn off. If you plug it into the computer while it's off it was recognized. The RCA software didn't recognize it, but when I doubleclicked the drive in "my computer" it asked me to Format. after I formated, I unplugged it and plugged it back in, and the RCA software picked up the device
Posted on Feb 16, 2009
Hi, i own a sony walkman mp3 player of B series that is NWZ-B135F once i inserted my mp3 player into my friends pc later my player has stopped working (the player does'nt switch on) please help me please...
Perform the following steps to resolve the issue.
1. Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed.
2. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
3. Ensure that the HOLD function is not activated.
NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
4. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object. Reset button is located near the Strap hole.
NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
5. If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Thanks for using FixYa.
Apr 07, 2011 | Sony Audio Players & Recorders
I am charging the battery of a brand new purchase. Do I need to let the battery charge fully, ie; the 3.5 hours before I can use it? I keep getting a, "Key LOCKED, system shutting down message on the...
For the initial charging, YES, you need to follow what's on the manual. If it requires you to charge the player for 4 hours as the initial charging, you need to leave it connected to the wall outlet for 4 hours, so that the battery life will become longer.
Though the key is locked, it's still charging. As long as it's connected to the outlet.
Thank you.
Nov 03, 2010 | SanDisk Sansa e200 MP3 Player
My mp3 player is become switched off as soon as it gets initialized....... it occures manier times. please help
My transcend MP3 didn't start on when i connected to the battery charger. When i charge the battery then i pushed the start button, it only initializing system...Please help me
how can i fix this problem?
Mar 07, 2010 | Transcend T.sonic 610 MP3 Player
Full battery, doesn't start up
Mine is doing the same thing, and I've tried the same solutions as well as trying different computers and cables to recharge.
The one other possibility for mine is that I damaged it using a generic charger in the car that was supposed to work for "most" MP3 players. It did seem to - I mean, the player didn't blow up, catch on fire, or stop working! - but a day later, it collapsed. Maybe a coincidence, maybe damage from the car charger.
I'm guessing that it's time for both of us to send the units in for battery replacement.
Good luck with yours.
Jul 30, 2009 | Sony NWZ-E438F Digital Media Player
RCA MP3 will not Initialize after not using the MP3
On the back of the mp3 player has a reset button, you can use a back of and earing and push the reset button. Some mp3 players can have a thing to connect in the computer tower. Some come with cords. If it comes with a cord. Just hook it up and let the mp3 player charge. When it's done charging it will say battery full. It may take all night to charge.
Mar 11, 2009 | RCA OPAL M4001 MP3 Player
Charging
You should charge the battery (on the first charge) for 18-24 hours. They 'initializes' the ions in the battery.
A way to fix this if you didn't do this the first time is to drain the battery entirely and charge the battery on the WALL SOCKET for 24-48 hours.
Otherwise try a new charger or cable, if its none of these. Its the battery. If you are still in Warranty (1 year) or AppleCare (3 years), take it to any Genius Bar in any Apple Store
Dec 31, 2008 | Apple iPod touch
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Sansa c240 battery issue
Does it indicate that it is fully charged? If it does, I would return it or have it replaced. You have a 1 year warranty from SanDisk. SanDisk Technical Support 1-866-726-3475 If not, try using a different USB port on the computer, preferably one in the back. Best of Luck.
Sep 14, 2007 | Audio Players & Recorders
Screen says battery is full, but wont turn on
I read somewhere that even with a functional lyra, when it displays "battery full", you should keep charging for another hour. This is said to extend battery life and give you an extra 2-3 hours of power. Either this is perfectly normal, or it indicates that the battery reading tends to be inaccurate. In any case, try leaving it charging even after it gives you the message. Another thing to consider is, how long has it been in the box? I'm not sure about lithiums, but most rechargeables I know live longer when used. Live it alone for too long and you shorten it's life. Could be good to get a second opinion on this battery thing though. If there's a warranty, don't let it waste. Good luck
Jun 20, 2006 | RCA Lyra RD2840 MP3 Player
77 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
