Question about Dell A215 Computer Speakers
Only one speaker works.
I have the Dell A215 speakers and they both used to work and then the one with the power knob on it stopped working completely. I used to be able to wiggle the cord that you plug into the sound outlet on the CPU and it would work again, but it's not anymore. Does anyone know what my problem is? And if I have to open my speakers up, how do I do it? I see a screw on the back bottom of my speaker but I've been trying to unscrew it with no success of it coming out. Thanks for your time and patience. -David
  • 2 more comments
  • David Remanjon Jun 27, 2007
    Oh, i meant the cord that you use to plug into the sound outlet on the CPU, I wiggled the end of the cord that is on the speaker itself. And I tried plugging the speakers in my CD player and it's the same thing. Only the speaker without the power knob works.
  • Anonymous Oct 26, 2008
    i have 2.1 speaker system. it sounds perfect on other pc or music systems.
    but when it is pluged to my pc, then only one speaker sounds while there is no sound in the other.
  • bullfrogblue Oct 28, 2008
    I have the same problem, the speaker with the nob only works sometimes,
    very rearly. Don't know why it doesn't work, but it just starts working
    sometimes for no apparent reason.
  • lazbarian Nov 27, 2008
    I have exactly the same problem. I used to wiggle the cord on theback
    of the speaker with the volume control and it would workoccasionally
    but now it doesn't work at all. I'm trying to openthe unit but only see
    one screw in the back inside a long tunnel and Icannot get the screw
    out no matter what screw driver I use. Isuspect a broken solder joint
    somewhere inside which I can resolder ifI manage somehow to open this
    thing up. I'll let you all know howit goes if I figure out where the
    other 4 screws are that a previouscontributor wrote in about.
It took me a while, but I figured it out and successfully repaired it. Probably not worth the 3 hours I put into repairing a $19 speaker system, but am I ever proud I repaired the set and its not in some landfill in China
Here's what to do:
1. Remove the screw at the lower back of Right Speaker (the one with the volume knob that is broken and without sound). You will need a long thin screwdriver - and this screw is very, very hard to remove.
2. Carefully remove the fabric speaker faceplate on the front side by pulling at the edges carefully,
3. Under the faceplate there are 6 screws. Remove the lower two and upper two (securing the top part of speakers)
4. You should be able to separate the back and front halfs of the speaker enclosure now.
5. Desolder the speaker stereo audio input cable from the printed circuit board and replace by soldering in a replacement cable. I scavenged a replacement cable by cutting the cable for a set of stereo headsets I got for free on an airline flight. There are three wire, white (left channel), yellow (right channel), and black (ground), You need to remove and resolder all three wires.
6. The problem is that the existing stereo input cable develops an open circuit somewhere in the cable for the right channel. All you need to do is take ou the old cable and solder in a new replacement cable.
7. Reassemble and your good to go!!!!
Posted on Nov 28, 2008
I had the same problem, and replaced the sound card thinking that would work. It didn't, but when fiddling around with the cables, I discovered I could get both channels to work if the green plug that goes into the back of the computer wasn't plugged in all the way. I know it sounds weird, but you can try this solution.
Posted on Mar 18, 2009
Same problem with mine. there are screwes, u have to open up the face plate...and there are 4 speaker screws and 2 to open it up. there is also one in the back..but i cant get to that one..u need a small but long screw driver for that.
i m guessing its the power jack on the speaker itself beacause when you put the speaker on its back and wiggle the power cord on the speaker it starts to work. but as soon as u move it it stops.
if n e one finds the solution please post.
thanx in advance.
Posted on Nov 14, 2008
Urgh got the same thing just happened to me. The speaker with the volume control stopped working. it happened periodically before this- turning it off and back on again would usually fix it. This time i went to do it, lo and behold it didn't fix itself this time. Along with some other problems with the pc, I'm really regretting buying a dell in the first place. There are no screws visible on the thing so choices are bust the thing open, void warrenty /return to manufacturer/buy a decent set of speakers instead.
Posted on Oct 01, 2007
I have the same problem, the speaker with the nob only works sometimes, very rearly. Don't know why it doesn't work, but it just starts working sometimes for no apparent reason.
Posted on Oct 28, 2008
    Problem Solver:
  • 10 Answers
I don't think it's the speakers, I suggest trying the speakers on another pc, or plugging them into a walkman/personal cd player, and see if it does the same. I'm gearing towards the output socket on the PC, because you said "I used to be able to wiggle the cord that you plug into the sound outlet on the CPU and it would work again, but it's not anymore". If the sound is built into the motherboard, then I would suggest buying a new soundcard, then disabling the on-board sound, using the BIOS setup, then installing the new soundcard and drivers, either way, on-bord sound or not, I suggest purchasing a new souncard.
Posted on Jun 18, 2007
Where do I pug the speakers in ? I need a Picture,Show me the picture.
    • 1 Remove the Dell A215 speakers from the box. Place the speakers in your computer area. The speaker with the volume knob is the right speaker and should sit to the right of your keyboard. Place the other speaker to the left of your keyboard.
    • 2 Plug the left speaker into the right speaker. The left unit has an orange-brown plug that connects to a similarly colored port on the back of the right unit. The other end of the cord is fixed to the rear of the left speaker.
    • 3 Insert the two-prong end of the power adapter into an electrical outlet. Plug the other end into the black power port on the back of the right speaker.
    • 4 Insert the main audio cable into your computer. This cable is fixed to the back of the right speaker and has a green head. Plug the green connector to the green audio-out port on your computer. This port may be on the front or back of desktops or on either side of a laptop.
    • 5 Turn the knob on the right speaker clockwise to turn the speakers on and increase the volume. Turn it counterclockwise to lower the volume partially or all the way to turn the speakers off. The speakers should work automatically on any computer with a sound card.
Let me know if this solved the problem and good luck..
Sep 09, 2011 | Dell A215 Computer Speakers
Ok so my speakers are not working. the green light is on but no sound comes out and i know its pluged in right
try another speaker. if OK. the problem is on Dell A215 Computer Speakers. if other speaker don't work.
Check your soundcard. reinstall the driver. and make sure the driver is install correctly.
Aug 25, 2010 | Dell A215 Computer Speakers
Speakers dont work
if the pc runs windows vista they won't work in less they have a power but if the pc runs windows xp try to install the drivers for the speakers here is the download link http://www.user-guides.co.uk/download/free/freedrivers/free-drivers-installing-dell-a215-speakers.html
May 29, 2010 | Dell A215 Computer Speakers
No sound will come out please help
Speaker Manual Dell A215
http://support.dell.com/support/edocs/acc/ada215/ada215.pdf
Ensure speaker port is working fine by connecting headphones.
Use Volume Knob to turn on the speaker
Jan 14, 2010 | Dell A215 Computer Speakers
The one with the volume/off knob works, the other
This problem is more than likely to be caused by damage to the wire going to the secondary speaker. For example if the speakers have been moved around alot, the wiring can get twisted and cause a break internally. Therefore causing a short. This may not be the case with your problem but I hope it helps
Nov 16, 2009 | Dell A215 Computer Speakers
Driver for A215 speaker
Here's a link to all of Dell's audio drivers. If you're not sure which one to choose, go to the search bar and enter the model number of your computer.
http://search.dell.com/results.aspx?s=ge...
Hope this helps.
May 28, 2009 | Dell A215 Computer Speakers
Speakers Don't Work Properly
Go to control panel > Sound and Audio Devices > Speaker volume.
If still don't solve the problem check the device.
Feb 20, 2009 | Dell A215 Computer Speakers
Dell Speakers A215
Try going to support.dell.com and entering your Service Tag. Then click on drivers and downloads and download and install the audio driver that they currently recommend for your machine. Sounds like a driver problem and something that wasn't set properly after the computer was reset.
Dec 18, 2007 | Dell A215 Computer Speakers
Dell A215 Computer Speakers Logo
2,028 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
