Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Monitor problem Dell 15" E151FPp LCD monitor goes blank after startup and i have to restart the PC for it to come back. I changed the power options in control panel that didnt work.What do you suggest?
  • Alister Allert Jun 26, 2007
    Solved the problem the primary problem was the onboard video but by extension there seems to be a problem with the mainboards of the GX270 (bad capacitor i believe) an AGP card should do the trick for now. thanx for your help
    Problem Solver:
  • 15 Answers
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Posted on Jun 19, 2007
SOURCE:
I HAVE MONITOR DELL E151FPP, THE PROBLEM IN THE RESOLUTION WHICH IS 640 X 80 ONLY
Make sure you've downloaded the driver for your video card. As long as that is installed and it supports higher resolutions, you should be able to go to your system settings and change it (this process will depend on your operating system).
Mar 30, 2011 | Dell E151FPp 15" TFT LCD Flat Panel...
It does not have DVI port, only VGA.
http://support.dell.com/support/edocs/monitors/e151fpp/En/attach/attach.htm
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 17, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
E151FPp (Gray) 15 in. Flat Panel LCD Monitor: I am not able to get DIplay Driver for my LCD moni...
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Dell E151FPp 15" Flat Panel LCD Monitor
My monitor flashes on at startup but then goes blank
I will assume you have already try this monitor with other PC and new VGA cable with the same result.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Power Board Dell E151FPp
Did you check the fuse PF751, it should be less than 1 Ohm?
Also look for cold solder joints.
Mar 23, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
No display but power led is on
sounds like a video card problem in your pc. If you are using the onboard video output on your motherboard, you probably need a new one. If you are using a card that has been added to the board in a slot, try your onboard output (looks the same)
Jun 15, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Cannot get me monitor out of sleep mode, please help?
Hi
Pls check the power management properties in device manager to check if the option to wake the computer from sleep for the keyboard and mouse are enabled.
You may also try to change the power plan or create a new power plan and check if you are able to wake the computer from sleep.
If this problem started a few days back, then you may try to do a system restore.
Feb 26, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Monitor goes black
it depends whether it displays anything. There's only one fuse which determines if the power is on or nor. If your monitor turns on, I would not look for the bad fuse.
Sep 29, 2006 | Dell E151FPp 15" TFT LCD Flat Panel...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
137 people viewed this question
Ekse
Clive
Clive
