Question about Raymarine C80 GPS Receiver
Fish finder not receiving data screen says no data source available Checked connections in back of unit & tried cleaning transducer
  • Anonymous Mar 25, 2014
    the unit itself
  • 16 Answers
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Posted on Dec 28, 2007
Lot of interference with unit transducer mounted on trolling motor when trolling motor is being used. Then clears up when not used.
Some how you have Radio Interference conflicting with your unit. The RF as it is called, may be coming from the engine. Try to connect to an INDEPENDENT power supply for the Eagle and not the same source your trolling motor. You seem to be getting line interference.
Feb 02, 2015 | Eagle Fishelite 502c Igps Fish Finder...
I need to connect a Garmin 160 transducer to a garmin 120 fish finder
If I may inquire, how many pins on the transducer and on the fishfinder.
Hope to hear from you and pls post back the requested information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Garmin GPSMAP 188 Fish Finder/GPS Receiver
797c GPS fishing system , has no sat. signal. could it just need an update
sounds to me your sat. receiver has gone out is it a internal or external receiver if external replace it if internal . . .new unit
Nov 14, 2013 | Humminbird 797c2 Si Combo Color Fish...
Wide view fish finder
may want to call or email the manufacture of the unit for that info
Sep 30, 2017 | Eagle Boating
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
Navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Sep 20, 2008 | Navman F4100SX Fishfinder - W/ Transom...
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Raymarine C80 GPS Receiver Logo
471 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Goldi Kunal
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
