Question about Toshiba TE55T11 55" Rear Projection Television
Toshiba TE50T11 Chasis TAC9955 won't turn on.
I have a Toshiba TE50T11 Chasis TAC9955 that will play for a while and then turn off and the front red led will flash. The set will not come back on unless I remove the back cover and press connectors, capacitors, etc. Wiggle them and then the set will play for days even. But eventually will go back to red led on front just blinking. I can't see any pattern to the blinking. Any known loose connection issues, capacitors, etc.
  • Anonymous Mar 02, 2008
    wont come on just blinks red light.
  • nwreeds May 25, 2009
    we have the same problem we use to just unplug it but that doesn't work now. what can we do.
Transister for the power supply is blown need to replace it to fix the problem
Posted on Nov 12, 2007
  • 1,476 Answers
Based on the fact that when you remove the back and press on things making the set work for a while I would say that you have bad (cracked or cold) solder joints. If you can solder, disconnect power, remove the board (the one you normally have to press) and solder all the connections or at least any feed throughs, major power componnents and anything suspicious looking under magnification. If you can not solder you will need a reputable shop to look at it. Cost should not exceed $125 US. Good Luck.
Posted on Jun 19, 2007
2 Suggested Answers
SOURCE:
  • 133 Answers
SOURCE: TV turns off after lightning strike
please post how many time it blinks, this does help us solve your problem.
Posted on Aug 05, 2007
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Jul 25, 2007 | Toshiba TE55T11 55" Rear Projection...
I have a toshiba te50t11 50
Please confirm brand and model AND what your problem is.???
Mar 11, 2012 | Toshiba Televison & Video
Toshiba V231 UK VHS manual is lost. Since last week I disconected and then replaced to my Toshiba TV. I can not Autotune it back to play VHS recvordings. I get sound but the tracking just flickers up the...
I believe you are using a RF wire Connecting a VHS, then searching TV station is an old way. I would recommend you use a RCA wire. By so doing, you won't need to tune any station on your TV. All you need to is select Source (AV) on the TV and the VHS would automatically display on your TV.
Below is what the RCA cord looks like:
The yellow stands for video (display), while the red and white stands for audio left and right (sound).
Purchase this cord from any electronics part store within your area, it's not expensive at all.
Look at the back of your TV, connect the yellow cord to "Video IN", connect the red and white to "Audio IN". Then connect the other end of the cord to Yellow: "Video OUT", and red or white to "Audio OUT", at the back of the VHS.
After the above connection, turn on the VHS, insert a tape, and press play. While the VHS is play, turn on the TV, select Source (AV) on your TV and your VHS will start displaying and you will hear sound.
I hope the above is clear. If you need further assistance, please let me know.
Regards.
Sep 20, 2011 | Toshiba Televison & Video
My ps3 won't show on tv but it show that it's playing
Are you saying that it has sound but no video?
Plug only the video plug (yellow) to the TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 07, 2011 | Sony Playstation 3 (PS3) Console
Convergence problems with the Toshiba TE50T11. Have tried to fix by remote and the colors will not align as they should. Left side of screen has blurriness, almost a 3d effect with alot of greenish tones....
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Dec 02, 2010 | Toshiba TZ50V51 50" Rear Projection...
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Convergence issue toshiba
Yes that model also uses STK392-110 ICs as do most Toshiba projection TV models
May 05, 2008 | Televison & Video
Cracked screen
rmaura,
My Toshiba TE55T11 also has a broken screen. I contacted the Toshiba hot line in Australia and they said that they don't make screens for this TV anymore. so i just got a new Toshiba 72CM9UA.
I hope this info is useful!
Oct 12, 2007 | Toshiba TE55T11 55" Rear Projection...
Toshiba TE55T11 55" Rear Projection Television Logo
666 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
