Question about Sony VAIO VGN-FJ270/B Notebook
Sony VAIO, Keyboard, Update Permission etc
I have a Sony FE41M laptop
Few weeks ago it started to behave strange
- Shortcut keys (ctrl_x etc). stopped working, itwas only possible to use mouse in place of shortcut
- After some time, when I log in, it started togive, reset password, while the password is okay
- It takes some time for the keyboard to be recognizedby the system
- I formatted it and the same problem persists
- I even replaced the keyboard with externalkeyboard and it still does not work
- I used a booted using XP CD and it still doesnot recognize the Keyboard
Do you have any tip
Thank you
es
Shortcuts have locked up on my pc
Conflicting Extensions
Add-ons, also called plug-ins or extensions, are mini-applications that attach themselves to independent software and add extra capabilities to the program.
Extensions can change a browser's interface, alter the behavior of existing operations, add new functions or install in-browser support for programs like Shockwave Flash or Adobe Reader.
Because these extensions make changes to the overall operation of a browser, they can also affect the shortcut keys.
Most browsers offer an option to run the application with add-ons disabled; if the shortcut keys work when extensions are turned off, one of the add-ons is at fault.
Key Reassignments
Programs like MapKeyboard, SharpKeys and KeyTweak can reassign the functions of each key on the laptop keyboard.
If the computer is running a non standard keyboard layout, certain keys might not behave or respond normally.
For example, if the "Ctrl" key has been disabled or is set to work like "Shift," shortcut keys won't work as expected because the keyboard is no longer using its default mapping.
If the keyboard layout has been changed in the Dell laptop, the registry will contain a Scancode Map entry in
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout or the language bar will show a keyboard language different from the default ("English (United States)," or "EN," for Dell laptops purchased in the U.S.).
Virus Infection
Malicious software can affect the function of peripheral components like the keyboard and mouse.
If the keyboard is exhibiting strange behavior for example, if certain keys do not respond or if keys output unexpected letters a virus is most likely the cause.
Running an anti malware software from within Safe Mode accessed by pressing "F8" on the Dell logo screen should remove any viruses interfering with keyboard response.
Browser Software
Upgrading or downgrading a browser on the PC can affect the Internet shortcut keys associated with that program, especially if the version removes a function that was once associated with a particular keyboard combination.
Alternatively, if you've switched to another browser, you might find that certain shortcuts that worked in the previous browser don't work in the new one.
For example, while "Shift-F10" opens a context menu in Internet Explorer, the same keyboard combination does nothing in Mozilla Firefox.
Hope this helps.
Nov 20, 2012 | ASUS Computers & Internet
Hi,Sir, I am using the Sony Vaio Laptop, VPCEB46FG Model and its fn(Hot keys driver is missing).Please send me the link for the same. I was not able to find it on sony e-support. Kindly help out for the...
  • you can verify if the Sony Vaio Event Service has been started (by ctrl+alt+del, then Processes)
  • Install keyboard driver (http://www.sony.co.in/support/product/vpceb46fg, then Downloads, etc )
Jul 05, 2011 | Sony VAIO E Series VPCEB36GX/BJ Notebook
Keys have changed.. I pressed o and and it becomes 6
you have to reinstall your operating system...better you can visit any sony authorised service centre. They will help you.
Apr 02, 2011 | Sony VAIO VGN-SZ330P/B Notebook
I have sony vaio EB series laptop, my problem is that when I type 1 it type 21, when 3 it type 0.3, when 1 below f1 key it type 1 and open help window. there are other similar keys behaving same way. I got...
Hello
If the new keyboard is behaving same, then try to plug in an external keyboard to see if that works okay. You can use any USB keyboard. If this keyboard works, you have a hardware problem and need repair from Sony Support.
Hope this helps, Good Luck
Dec 31, 2010 | Sony VAIO VGP-WKB1 Keyboard
About a week ago I started noticing that when I used the letter y it would make my cursor jump backwards, sometimes a few spaces but sometimes several lines. What could be causing this? It only happens if...
Does your keyboard have a pointing device in the centre? (small button that is an alternative to using the touchpad)
If you have that then it is likely that you are touching it while typing and moving the cursor inadvertently.
You can disable that device, but I would need to know what make and model of laptop you have to advise further.
Happy to help if you reply here with a comment
Mar 06, 2010 | Sony VAIO VGP-WKB1 Keyboard
Sony Vaio VGN FE41M
If you have admin login, you should be able to use this to set up another admin account or a user account.
Try pressing F8 on startup and try and login to the computer.
Jan 10, 2009 | Sony VAIO VGN-UX280P Notebook
Sony vaio touch pad not working.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
Oct 28, 2008 | Sony VAIO VGN-SZ460N/C Notebook
Sony vaio geforce driver
Try to reinstall the driver.
You can get it from www.nvidia.com
If worse comes to worse, you could always reinstall windows.
Sep 07, 2008 | Computers & Internet
Sony VAIO VGN-FJ270/B Notebook Logo
241 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
