Question about Mitsubishi WS-55511 55" Rear Projection Television
TV has dim picture
Mitsubishi, 55" had since 2003, tv is fuzzie when turned on & picture shakey, clears up after tv warms up. tv brightness is low.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would seem to be heat related and/or a cold solder issue. I doubt very much if any major component is defective, at most probably would be a capacitor in the main B+ line leading to the HOT (horizontal out). But that has to be confirmed visually and/or a voltage check on initial power up. best approach would be to open the rear, do some voltage measurements before warm up and after warmed up. Compare these readings and reference the Service Manual. Of course special care and attention since you would be working on a live set.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 17, 2009
Auto-dimming problem
It depends of the set--may have a light sensor built in and if so when light in the room changes the brightness on the TV and contrast will vary.
May 30, 2012 | Vizio Televison & Video
Dim picture
First, try adjusting your Brightness and Contrast in the Video or Picture settings menu. If this doesn't fix the problem, your LCD Back Lights may have burned out. You will need to either replace the Back Lights, or the LCD screen if they are built-in, take the TV in to a TV repair shop, send the TV back to Mitsubishi for repairs, or replace the TV with another.
Here is the link to Mitsubishi-TV Support: http://www.mitsubishi-tv.com/support.html
Feb 25, 2011 | Mitsubishi WD57831 Television
Mitsubishi TV Model TS-4557 Two problems: 1) The picture is very dark despite the brightness control being at the maximum. 2) The picture is fuzzy - particularly when there is text on the screen, to the...
the problem is picture tube base which connects picture tube to circuit board ..inside ur tv..take tecnical help of service men to replace the p.t.base
Mar 13, 2010 | Mitsubishi TS-4557 45" TV
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
I will to know the code for the precision Tv
Hi, I have a sharp 32sf56b. sound OK. Picture went dim and fuzzy. Clears up a little when turning brightness control all the way down. Picture has no snow. Can see fate vertical line on screen
Mar 08, 2009 | Televison & Video
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Tv picture is shakey
Bad capacitors on Hyper module = no longer available, but
can be rebuilt by PTS Corp or a qualified tech...........T.
Feb 13, 2008 | Toshiba 42H81 42" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
