Question about Candy DQW150 Front Load Washer / Dryer
I am trying to change the element on a candy cna 166
I have taken the back off and found it and i have disconnected it and removed a nut but it doesnt want to come out . do i just lever it? i dont want to break the machine
  • df118 Jan 20, 2009
    Thanks. It turned out the one in there still works anyway. but now i know and i have a spare heater element i am ready if and when i does go!
  • Candy Master
  • 3,463 Answers
Yes, you do have to lever it out, if you have removed the center nut completely, try and pull the metal plate as far forward as you can, this should expose the rubber seal, this is what is holding the heater in.
Lever round the edge of the seal, and try to force it out, be careful,as you can break the plastic moulding (expensive)
If this does not work, then try cutting through the seal with a stanley knife, and remove it piece by piece.
You will have no trouble getting the new one back in.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
I have a Dayton Style No. 166 Candy Scale that doesn't work - are ther any schematics or manuals available?
Shouldn't be anything too hard. Have you taken off the front to check inside? You can email me pictures at klmlilli@aol.com maybe I can help.
Jun 22, 2011 | Garden
Tip
Procedure for replacing heating elements for Dualit Bread toaster
91b14ba.jpg370ea57.gifPROCEDURE
PROCEDURE FOR REPLACING ELEMENTS
A. Disconnect the toaster from the mains
B. Remove the crumb tray.
C. Unscrew feet and remove base plate.
D. D. Loosen the two nuts and slide back element retaining strip.
E. Note the position of the connecting links and wires, then unscrew nuts which secure them to the broken element, bend back the connecting links, pull out the old element and slide in the new element. Fasten connecting links back to their original position by tightening the nuts.
F. Slide back element retaining strip and tighten nuts.
G. Make sure that you have the high wattage elements marked ?CENTRE? in the middle and the two low wattage elements marked ?END? at ends.
H. Refit base plate, feet and crumb tray
on Apr 02, 2010 | Kitchen Appliances - Others
Model is Candy Alise 1200 SE fault is, trips house earth leakage breaker as soon as washer power switched on!
Short circuit on machine Disconnect the heating element located at the back of machine pull off the two wires then try switching on for fault, hope it clears......
Jun 13, 2011 | Candy Washing Machines
I need to remove the entire passenger side rear suspension. Does it go through the trunk or the back seat? If so how do you remove the back seat?
REMOVAL & INSTALLATION 1983-86 Models
  1. On 4-door sedan, remove the package tray and vent duct.
  2. On hatchback, remove the speaker grilles.
  3. Disconnect the brake line from the wheel cylinder. CAUTION
    Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes and wash your hands thoroughly after handling brake fluid. If you do get brake fluid in your eyes, flush your eyes with clean, running water for 15 minutes. If eye irritation persists, or if you have taken brake fluid internally, IMMEDIATELY seek medical assistance.
  4. Remove the brake line from the brake hose.
  5. Disconnect the brake hose from its bracket on the shock absorber.
  6. Loosen, but do not remove, the nut holding the suspension support to the shock absorber.
  7. Unbolt the shock absorber from the rear arm.
  8. Unbolt and extract the shock absorber from the body. To install:
  9. Attach the shock absorber to the body and tighten the 3 nuts to 17 ft. lbs. (25 Nm).
  10. Engage the shock absorber bracket with the carrier and install the hardware. Tighten the nuts to 119 ft. lbs. (162 Nm).
  11. Tighten the center suspension support nut to 36 ft. lbs. (49 Nm). There is a bearing located under the suspension support dust cover. Remove the dust cover and pack the bearing with multi-purpose grease. Once packed, reinstall the dust cover.
  12. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  13. Have the rear wheel alignment checked.
1987-88 Models
  1. On wagon models, remove the toneau cover holder.
  2. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  3. Remove the rear wheels.
  4. Using the proper size flare nut wrench, disconnect the backing plate hardware.
  5. With a flare nut and a back-up wrench, disconnect the brake tube from the brake hose and use a small plastic container to collect the brake fluid.
  6. Undo the clip and disconnect the brake hose from the shock absorber. NOTE: Before the axle bolts are removed, the axle carrier must be supported with a jack.
  7. Support the axle carrier with a floor jack and remove the mounting bolts and nut. Disconnect the axle carrier from the shock absorber.
  8. Support the shock absorber firmly by hand and remove the three mounting nuts. Remove the shock absorber from the body. To install:
  9. Position the shock absorber onto the body and support it firmly by hand. Install the three nuts and tighten them to 23 ft. lbs. (31 Nm).
  10. Attach the axle carrier to the shock absorber with the nuts and bolts. Tighten the nuts to 166 ft. lbs. (226 Nm).
  11. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  12. Bleed the brake lines as described in Section 9.
1989-96 Models
  1. On the 4-door sedan, remove the package tray and vent duct. On 1992-96 models, it will be necessary to remove the rear seat back.
  2. On the hatchback, remove the speaker grilles.
  3. On the wagon models remove the tonnue cover and rear seat back.
  4. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  5. Remove the rear wheels.
  6. Disconnect the brake hose and the ABS speed sensor from the shock absorber.
  7. If equipped with ABS, disconnect the Load Sensing Proportioning Valve (LSPV) spring from the lower arm.
  8. Disconnect the stabilizer bar link from the shock absorber.
  9. Support the rear axle and loosen the 2 bolts from the lower end of the shock absorber.
  10. From inside the vehicle, unbolt the upper support. Fig. 1: A rubber cap covers the rear shock absorber tower nut 89558p01.jpg
    Fig. 2: The upper shock absorber tower is retained by the center nut (circled) and three surrounding nuts 89558p02.jpg
  11. Lower the rear axle carrier and remove the two bolts.
  12. Remove the shock absorber from the vehicle. To install:
  13. Install the shock absorber assembly onto the vehicle.
  14. Connect the brake hose and the ABS speed sensor to the shock absorber.
  15. Connect the stabilizer bar link to the shock absorber.
  16. Install the wheel and tire assembly.
  17. During installation, please observe the following tighten specifications:
    1. Tighten the shock absorber-to-body bolts to 29 ft. lbs. (39 Nm).
    2. Tighten the shock absorber-to-axle carrier nuts to 166 ft. lbs. (226 Nm) on 1988-91 vehicles and 188 ft. lbs. (255 Nm) on 1992-96 vehicles.
    3. Tighten the suspension support-to-shock absorber nut to 36 ft. lbs. (49 Nm) on 1988-91 vehicles. On 1992-96 models, tighten the stabilizer bar link to shock absorber retainers to 47 ft. lbs. (64 Nm).
  18. Install the rear seat back, vent duct and the package tray as required.
Dec 18, 2010 | 1986 Toyota Camry
Mildew and 'yuck' in the bottom inside dishwasher...how can i clean and disinfect?
I have an older dishwasher also and recently my wife also complained about it not cleaning right… so me being the man I am tried in vain to clean the things…
Bought new spray arms online and installed them in minutes…now the thing works like new…
However I have also found that if the heating element goes bad then that also can mess things up bad…
So I would buy new spray arms, and also check out the heating element to make sure it is working…
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 31, 2010 | Miele Optima G2470SCVi Built-in Dishwasher
How do a change the element on a candy oven , can't get to the old element
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Candy F248P Electric Single Oven
Heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Apr 18, 2008 | Candy DQW150 Front Load Washer / Dryer
CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Jan 22, 2008 | Candy AQW130 Front Load Washer / Dryer
Cic60 candy tumble dryer
Generally, these units are gotten into from the back panel. Be sure to disconnect the power. There are two breakers linked together.
Dec 15, 2007 | Candy CDC266 Dryer
Candy DQW150 Front Load Washer / Dryer Logo
170 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
