Question about GE JES1456 Microwave Oven
Not working at all
This morning the microwave was making all sorts of beeps. They were long and loud like an alarm clock. My daughter and I not realizing it was the microwave were looking all over the house for the source of the noise. If the screen was flashing a message, we missed it. Anyhow, now it is completely dead. There is no screen, no light when you open the door...nothing. I have unplugged it and plugged it back in several times. What happened? Have four kids one of which is a baby so I need the microwave.
Thanks
J Porcello
  • porcello Jan 16, 2009
    it tuned back on all by itself...it was warm inside so perhaps baby hit something and it just overheated???? THink it is working the clock screen was just flashign and thanks to the online manual...I now know how to lock the baby out of it just in case she was the one pushing buttons.
    Still wondering what happened if someone knows....
  • GE Master
  • 9,098 Answers
I would suspect you have a shorting membrane keypad.
This can cause it to come on by itself, and running it empty will cause it to overheat, then the thermostat on the magnetron will cut power to the unit until the magnetron cools off again.
If it happens once, it's likely to happen again.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior.
So play it safe and stay with it while it's running!
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs, which would be dependent on the model number.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 18, 2009
1. Microwave noise 2. keyboard and beeping
Make sure oven is plugged into a grounded outlet, and that the outlet is actually grounded.
Although extremely rare, I have seen ovens where insects were walking on the back side of a control panel, and causing problems. Could also just be some sort of electronic failure.
Mar 14, 2016 | In Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Microwave quit, now has high pitched 'alarm'' going off
Can you turn the breaker OFF. or will this affect the other things on that socket?
Feb 03, 2010 | Microwave Ovens
Start microwave clockon sharp carousel oven
Not sure what the question is.. But if it is how to start the clock in a COUNT DOWN mode, then:
1, Touch TIMER BUTTON
2. Program in the length of time you want to use, before alarm comes on
3. Hit start button.
Unit will beep at the end the count down.
Kindly,
Jim
Dec 10, 2009 | Panasonic Microwave Ovens
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
GE JES1456 Microwave Oven Logo
129 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
