Question about Acer Aspire 1640Z Notebook
Which powercord to use?
I have a brand new Acer Aspire laptop and a powercord from another computer that I want to use it with. The battery says 11.1V and the powercord has an output of 15-24V. Does this mean the powercord is too strong for my laptop or is it safe to use?
    President:
  • 1,073 Answers
Yes, you should not use stronger powercord then your laptop can manage. That means a cord betwen 11v and 11,5v
Good luck to you
Nic
Posted on Jan 16, 2009
  • Acer Master
  • 13,433 Answers
In the bottom of the laptop you can find the input required, make sure the voltage matches the requirement and the connection is the right way.
from what you said I can't tell if its too stong, can you adjust the voltage? look in the bottom it is documented there on a label.
Where is the fuse located at on acer computer
There is none.
If it is a Desktop Computer (case) you will need a new power supply or a different one to test if that is really the problem.
on a laptop, try holding the power button for ~40secs with all power diconnected (no battery and no powercord).
then re-plug the powercord to see if it will turn on. Try a different powercord if it still wont turn on, or have it tested at an electronics store.
Aug 30, 2014 | Acer Aspire Computers & Internet
Where can we buy a battery of acer laptop aspire 4736/4736z/4336 series?How to take care of the battery of the laptop especially acer brand?
You should get it at your local computer store.
The replacement doesn't have to be an Acer. I have seen after market replacements, that work better than the original battery.
When you buy a new battery, you should consider looking at the number of mAh. It is written on the battery. This number indicates the time before complete discharge.
I have seen original Acer batteries that were 2200mAh, while replacements were 4400mAh.
So if the 2200mAh gives you 3 hours of working time before recharging, the 4400 could give you twice as much, so nearly 6 hours.
I have used the new Forza brand replacement batteries on a Acer Aspire One, and I am very glad with the results. I am not sure if they have the model you are looking for. if they have it, you should get one.
Hopefully this helps you
Mar 07, 2011 | Acer Replacement Laptop Battery-Acer...
I have the original power cord, but when plugged in, it wont charge. then it said my battery is dead. then i bought i new powercord on ebay and it keeps telling me to replace my battery. the computer is an...
Try to visit this site and look for updates:
http://us.acer.com/ac/en/US/content/drivers
Select note book
And ASPIRE
And number.
Its sometimes a driver problem due to it will not charge the battery.
Here could be an update
for your problem.
If not contact ACER support they will be glad to help you out.
Good luck.
Mar 03, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My Acer aspire one za3 will not turn on at all.
Either you have a bad ac adapter(powercord) or the power jack where you plug it in on the laptop is bad.The power board where the button you push is located could also be bad.Start with trying another ac adapter first.
Jul 06, 2010 | Acer Computers & Internet
Acer Notebook won't start up. At first we thought the powercord was damaged because the green light on it would blink. We got a new cord but the light just turns off and the computer won't start.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 23, 2009 | Acer Aspire 4720 Notebook
My Acer Aspire Laptop will not keep a charge......
It seem to me that the power input system is loose inside. You sould let a professional change it(if it's worth it). Or try to find a positin for the cable in witch it charges, then put some ducktape on it to stabilize it. It worked for me with my old laptop(as lond as U don't move it u should be fine:) Good luck.
May 07, 2009 | Acer Aspire 3680 Laptop
Is the battery pack dead? I was given a brand new
This is most likely a defect in the part of the laptop that uses the battery. You could try a new battery but most likely the laptop is in need of repair. If it is new you can contact acer and have it serviced under warranty. if you need further assistance let me know. Also please take a moment to accept and rate my solution.
Thank you,
lee
Apr 20, 2009 | Acer Computer AOA150 Notebook
Acer Aspire 5100 battery not detected
I am sorry to say you maybe buy a wrong replacement battery that cann't compatible with the original laptop battery pack at all,this laptop replacement battery is still rare in the market now.Wish this page will help you anyway.
http://www.power-battery.co.uk
Apr 04, 2009 | Acer Aspire 5100-3357 Notebook
My laptop is always crashing
are you getting blue screen are does it shut off
Mar 29, 2009 | Acer Aspire 5630 Notebook
Acer aspire 3680 will not power on battery and powercord are new
The battery is dead and/or your powersupply isn't working properly, or your memory is loose. first open the little door on the back where the ram is at and reseat it, then try to power it on, if that doesn't work take it to a professional nad have them test the power supply, if it tests ok, see if it is under acer warranty (acer.com) if it is send it in, if it isn't goto tigerdirect.com and buy a new one for around 300.00 don't waste any money on that computer.
Dec 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 1640Z Notebook Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
