Question about Tappan TGF363 Gas Kitchen Range
TAPPAN GAS RANGE, CLOCK CONTINUALLY BEEPS. IS IT AN ALARM FOR GAS LEAK OR ANOTHER PROBLEM?
I CALLED TAPPAN DIRECTLY. THEY HAD ME TRIP THE BREAKERS WHICH DID NOT HELP. THEN I HAD THE GAS CO COME OUT TO MAKE SURE THERE WASN'T A GAS LEAK. THE CLOCK STOPPED BEEPING ON IT'S OWN AFTER THE SERVICE MAN MOVED THE STOVE OUT TO INSPECT IT. THE NEXT STEP WOULD HAVE BEEN TO HAVE A TAPPAN SERVICE COME OUT, BUT I GUESS I'LL NEVER KNOW WHAT THE REASON WAS. HOPE IT DOESN'T HAPPEN AGAIN,.
Posted on Jan 17, 2009
I'm showing the code F2 and the alarm is sounding.. What's wrong?
Hi mrbright84,
F2 error code description is an electronic oven control failure. Please replace Replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Aug 12, 2010 | Tappan TGF320 Gas Kitchen Range
Tappan Millennia Electric Oven #316065306---"F1 comes up on digital clock and oven is beeping".
Hi rich750,
The F1 error code description is an electronic oven control failure. The easiest way to fix this error is to replace electronic oven control (also called EOC or clock).
Hope it helps.
Jul 30, 2009 | Tappan TGF320 Gas Kitchen Range
OVEN SHUTTING OFF, CLOCK FLASHING
ve continually had the same problem for years. Now the display flashes F1 and beeps continually and I have to keep the unit unplugged. I can use the burners and manually light them but the oven is unavailable because there's no power.
Mar 29, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan Millenia Range
Hi ChrisNess,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. If wiring is ok, replace the oven temperature sensor (RTD)
Hope this helps.
Jun 24, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Range 560S111PO1 Timer buzzer won't turn off
You have to set the timer alarm just right on the 12 'o clock position or .........................BZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Jun 12, 2008 | Tappan TGF363 Gas Kitchen Range
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
Whenever it is plugged in, it beeps incessantly. Ideas?
have you tried cancel or turning the power off then on ive seen some like that and the only to stop it is to replace the eoc or clock
Jan 20, 2008 | Tappan MPF500PBW Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
537 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
