Question about Samsung SW62ASP Top Load Washer
Machine stops with SE code
After each cycle my toploader washing machine stops with the code SE if I press start again it continues but it will stop again at the next cycle,like rinse or spin,sometimes it will repeat the same cycle again.What can be wrong and what can I do to solve the problem
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Posted on Mar 21, 2009
I also needed to jiggle the grey outlet hose at ground level for a little while, this seemed to help "kick it into gear"
Posted on Sep 14, 2009
Why won't my washing machine stop cycling?
Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
Machine stops at rinse cycle
are the taps turned on and not just one of them
Apr 28, 2012 | Washing Machines
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Washing machine has stopped mid-cycle
Your lid switch has failed. Take loose the control panel with the two screws in the back corners of the panel(Back of machine) Then flip the panel forward and your lid switch is on the left side cliped into the case. Replace it and your good to wash clothes again.
Nov 18, 2008 | Whirlpool Washing Machines
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Samsung SW62ASP Top Load Washer Logo
1,018 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
