Question about Motorola Mobility RAZR V3
Phone wont turn on
Motorola V3 RAZR when you press the on button the screen goes white then nothing happens,its been working fine up until now and i know its not the battery so whats happened,any help appreciated.
    Genius:
  • 1,074 Answers
Take it to a qualified tech to repair it, that is the best advice.you can say it is not the battery but you can never tell. good luck.
Posted on Jun 19, 2007
SOURCE:
RAZR V3 Screen flashes black and white
the firmware needs to be flash into teh phone take the phone to a mobile service center and have it fix.
Nov 25, 2008 | Motorola Mobility RAZR V3
Buttons
it is probabbly a bug in ur phone that is meesing around.
Jul 08, 2008 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Not charging
you need to try a new battery...if that does not work you have to get the phone reflash with the correct firmware.
Dec 20, 2007 | Motorola Mobility RAZR V3
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
V3 wont turn on
try press *#power @ the same time. if see something let me know.
Nov 20, 2007 | Motorola Mobility RAZR V3
Bootloader USB INIT
this happens to phones that have had water damage or something else and a way that might make it work is to take the battery out for no more than 60 seconds and put it back in and push the *,# and power buttons at the same time and if the blue screen comes up, while on the screen push the buttons and hold them until it goes normal. it worked for me
Oct 01, 2007 | Motorola Mobility RAZR V3
Phone screen is black
With the phone off, hold * and # keys and then press power button:
- If your phone screen still dont show anything then the backlight or whole screen is broken and you would need to replace or make a technician to replace the screen.
- If your phone shows a boot screen with serial numbers on it, then you would need to re-flash or reload the phone firmware to recover your phone. For that you may need some special software, a PC and your phone's USB cable. You can find tutorials and guides over the web.
To get out the bootloader screen you need to take out the battery and the re-flash procedure delete all your data so I recomend you to download it with your phones PC software.
Good Luck...
Sep 23, 2007 | Motorola Mobility RAZR V3
RAZR V3 DEAD SCREEN
This worked for me - I had to do it several times because I never figured out whether to start with the phone "off" or "on".
Press # * and the "end call (red)" buttons simultaneously and hold for several sections. Then power phone off and back on. I read this was the equivalent of "safe mode" booting for a RAZR. My phone has performed flawlessly since I did this on the 6th of February!
Aug 22, 2007 | Motorola Mobility RAZR V3
Switches on then nothing
i think you screen is jammed.send to fix shop
Jun 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
