Question about Indesit W 123 Front Load Washer
What size should the drain pipe be? - Indesit W 123 Front Load Washer
  • Indesit Master
  • 3,463 Answers
I am assuming you mean the drain pipe for the washer pipe to go in to. It should be a minimum of 1 and a half inches, it does not matter if it is larger than this, but it must be no less.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
Dont know how to hook up the drain pipe
The drain pipe in what? If we are talking about a sink, they sell multi size kits at lowes, home depot and any other hardware store. You need to know the size of the outlet from the sink and the size of the drain pipe you are connecting to.
Jun 07, 2012 | Dehumidifiers
If the load size is set anywhere at or above large, the machine keeps filling until it gets to a certain point and then continues to fill while draining at the same time.
The water is syphoning out the drain. Make sure the drain hose is not sealed to the drain stand pipe it drains into, and make sure the top of the drain stand pipe is higher than the washers tub. Try to extend it with a coupling and a peice of pipe up to 36 inches.
Feb 13, 2011 | General Electric WHDRE526EWW Top Load...
Dimension size for the ducting.
If you want the drain to be ducted the measurement is about the size needed for the drain pipe. Normally a duct with an OD- outer diameter -of about 3 inches should be sufficient to plug in the drain hose .
Make sure your drain hose fits into the duct as you can buy one with the drain hose taken out to sample.
Jan 03, 2011 | Siemens WFXD5200UC Front Load Washer
I have an old home that has a very space drain pipe. I bought a new Maytag top load washing machine. The drain pipe is too large for the drain pipe. 2 plumbers have told me the drain pipe will have to...
Whirlpool now own Maytag and with a W/P top load machine there is an adaptor which reduces the diameter of the drain hose. Not knowing the diameters of your drain hose, or the plumbing of your house, I can't say for sure that this is a remedy. However it's worth trying. Contact a Whirlpool stockist and see if the adaptor is the correct size for your new Maytag. Or you may be able to drain the new machine into a laundry tub which then flows into the house drain. This is a normal way of 'taking up the slack'.
I'm surprised your plumbers didn't suggest it.
Good luck Nomess
Nov 10, 2010 | Washing Machines
What size drain stand pipe should be used? Water is backing up from the drain. Machine is working great but water over flowing at the stand pipe
The problem is being caused because there is a blockage or restriction in the stand pipe, it needs to be cleaned out.
Feb 24, 2010 | Frigidaire GLTF1670A Front Load Washer
Water seeping back in washer after load is done?
Very possible your household drain pipe is almost the same size as the washers drain pipe. The house hold pipe should be approximately twice the diameter so as to allow equalising air in while water is being expelled from the washer. If at any time there is water flowback, it wont be forced into the washer pipe as it will now have an air gap.
Oct 06, 2009 | Kenmore 43142 Front Load Washer
Washer first begins to pump water, it comes out of the drain pipe
Laws of mother nature are the pipe is clogged or the size of the pipe is too small for the volume of water.Sorry I can't be moe helpful.Need help majortom350@yahoo.com
Aug 22, 2009 | Washing Machines
Moved into house with damaged joint in external soil pipe from upstaira shower room
You didn't state the size of the pipe or if it is PVC(plastic) or Cast iron. Two rubber couplings can be used to repair the joint. A 12" section, 6" on either side of the joint needs to be cut out. Cut a piece of schedule 40 drain/waste pipe same diameter as existing pipe to size(just under 12"). Take two rubber couplings (sized for your pipe) and place on each end of pipe joint, and tighten clamps.
This fix will work on cast iron pipe, but there may be another means of repairing the joint, so get back to me with more info about the pipe and joint.
Aug 02, 2009 | Plumbing
Sink drain slow
You can purchase a device from Home Depot that will clean out the drain. In the plumbing business, we call it a blow bag. But some call it drain dog and so on. It's a black rubber bag that fills with water and then when it reaches a certain pressure it blocks the drain but runs water through it until the clog is dislodged. You attach it to a water hose and push it into the drain as far as you can get it. Run it for 15 to 20 min. and then pull it back out. There are several sizes to accomadate the pipe size. You sill need the one that does pipes up to 2 inches. You will have to remove your drain assymbly under the sink to do this. While you have the drain assymbly off, you can make sure it is clean as well. This will clean out the garbage that collects in the pipe. Hope this helps.
Mar 20, 2009 | NRS A.H. Undermount Large and Medium...
Can't hold water
There is no drain valve.
Pull the drain hose up out of the drain pipe until there is only about 6" inside the pipe. Make sure there is a gap around the hose where it goes into the pipe so air can get in.
Make sure the drain pipe is higher than the water level in the tub.
Nov 17, 2007 | GE WJSR2070B Top Load Washer
Indesit W 123 Front Load Washer Logo
26 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
