Question about Whirlpool Duet GHW9150P Front Load Washer
Error Message H F
I have recently moved and ever since I installed it in my new home, the washer, at times stops in the middle of the cycle with the error message H F. Other times the washer does not drain completely. Any Ideas?????
  • 5,911 Answers
There is an "FH" fault code, but I'm not familiar with an "HF" fault. "FH" indicates that no water is detected entering machine or the pressure switch trip not detected. After 30 seconds if no water is detected entering machine and the valves will be turned off and the error code will be displayed. But, since you said there IS water in the machine this probably isn't the case. Press PAUSE/CANCEL twice to clear the display. Since you have water coming in, check the following: 1. Verify Drain pump operation - you should be able able to hear it turn on during the drain cycle. Make sure the drain pump isn't clogged. There is a reservoir that you can open with the machine turned off to see if there's anything trapped in the pump. You will need to remove the lower kick panel in the front to access. The drain pump is located just behind the kick panel and his white or gray in color. You may want to use a wet/dry vac to suck all the remaining water from the wash tub through the drain hose. This will make it less messy when you unscrew the pump cover. Water will run out if you don't. Now, keep in mind, there is always some residual water left in the tub after a wash, but only a small amount. 2. Make sure the Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch. This should be a clear plastic tube running from the wash tub exterior to a pressure switch inside the machine. You will need to remove the top cover to look inside the machine. There are three screws holding the top on from the rear. Make sure you unplug the machine first. 3. Verify there is not a siphon problem. That is, make sure you haven't sealed your drain hose in the standpipe so tight that the water never fills enough. If you don't leave an air gap for the drain, the water will attempt to fill, then run right back out through the drain line. 4. Verify wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Again, you will have to unplug the machine and remove the top cover. - Inlet valves should be located in the rear where the water inlet hoses connect to. Make sure they are not disconnected. - Pressure switch should be located in the rear of the washer on the right hand side as you are facing from the front. Make sure the electrical connection is connected and the air hose is not crimped, leaking, or has become disconnected. - Flow meter is a round (white in color on most machines) cookie-shaped device located somewhere between the water inlet valves and the dispenser. Make sure all connections are there. - Central Control Unit (CCU) is the "brain" of your washer. It is a gray rectangular box located in the central rear of the machine with all the wire harnesses going to it. Tough to say how you can determine if it is good or bad without replacing it. The board consists of several different relays and switches that control everything. Unfortunately, when one relay goes bad, you usually have to replace the entire board. 5. Check all hoses for possible leaks. If you check all your connections and don't find anything, more than likely you have a problem with your flow meter or pressure switch. I wouldn't rule out the fill valve, but you seem to be getting water, right? As a last resort, it could be your CCU which is the most expensive of the three items to repair (Usually over $200 for the part). I hope this may be of some help for you. Let me know if I can assist any further.
Posted on Jun 19, 2007
  • 35 Answers
Your flowmeter is not sensing water coming in might need replacement part.
Posted on Jun 25, 2007
I have had the same problem lately, and just about a minute ago found that on the right hand side (cover off) there is a 2.5" daimeter round black and brown contraption with a wire harness leading to it from the left and a .25 inch hose going straight down from the bottom side of the round contraption. Attached to the hose was 1/2 of a bracket or standoff that was broken, and just below that was about a 1" gash worn through the hose from the basket, I suppose from not being held in place due to the broken bracket. I will fix the leak and report back if it cured the FH code/interruption.
Posted on Jun 26, 2008
  • tonysmieja Jun 26, 2008
    Yep, that was it. And the culprit hose was dry when I inspected it, which was immediately after the FH code interruption. Must be a vacuum function or something (that right thar is my technical evaluation!). Anyway, problem solved. I will figure out a new bracket or standoff solution and off I go. Good luck to all of you, thanks for the help and direction, I appreciate it. Later.
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
We have a LG frount loader and just moved house and now it seems to me stuck middle cycle the message comes up isOE I have checked it is level water is on and the machine runs for 5 mins or so then stops...
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jan 15, 2011 | LG WM1814CW Front Load Washer
IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
Is an expensive part (£150/$200) plus labour so maybe time to just move on......
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Duet Vibrates the whole house on the spin cycle. it has started this only when we recently moved.
The key statement that you made was the fact that you recently moved. Some questions you may ask yourself:
Where was your washer installed in your old home as compared to where it is installed now?
Did you re-level the feet after you moved the washer?
Did any of the shock mounts come dislodged during the move?
Is the flooring in your new home substantial enough to handle the weight and spinning action of a front loader?
The following link can give you some things to consider when trying to figure out what may be causing excessive vibration:
http://www.fixya.com/support/r3633026-front_loader_excessive_vibration
You may not like hearing some of this, but I can assure you, I have dealt with this problem numerous times. In the majority of cases, substantial flooring was causing the problem.
Read through the link provided and let me know if you have any questions. I hope you find the information helpful in some way.
Mar 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung washer
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Samsung WF337AA Front Load Washer
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
597 people viewed this question
Sal De
Marvin
Marvin
jimorris77
