I dont know where to plug in my power cable from my GPU
I have a 9500 GT gpu with a little 2 pin power cable and i cannot see anywhere on the mother board where i can plug it in
  • 1 more comment
  • Anonymous Jan 24, 2009
    The card does not have a fan, but yet, there is a 2 pin cable supplied in the retail box. On the card, the connector is also present, however, the 2 poles need to be connected to the MB. I have not connected this to my MB, and the card works well! So why supply the cable? What voltage des it need if we were to connect the cable to the MB?
    Any experiences/suggestions?
  • Robert Graf May 11, 2010
    I can't see any power cable from the picture at the nvidia site. The only power connection I see is for the heat sink/cooling fan, which connects to a connector on the video card itself. According to the specs, the card only draws 50 watts, so I don't see why it would need a power supply connection. Do you have the manual?
  • Nicolas
    Nicolas May 11, 2010
    what model is it on your gpu?
    Scholar:
  • 88 Answers
I would look carefully on the video card. There is a place to plug in this fan.
Posted on Jan 18, 2009
Mainboard: g31 m7 te - power: antec hcg750 - gpu: gtx560ti
No the mobo is compatible with the Power Supply, and GPU.
And vice-versa.
Mainboard fan???????
You mean the Processor (CPU) fan?
I'm guessing I guess, because computer case fans aren't on the motherboard/mainboard/mobo.
(MOtherBOard)
You're getting power to the mobo, but the question is how much?
1) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
http://206.108.48.60/app/en/mb/introduction.php?S_ID=363&tab=1
The mobo will support Intel Core2 Quad-Core processors. Depending on which one, you may be talking about Up To 105 Watts of power,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Quad-Core_Desktop_processors
This is why LED's can light, and fans may spin, but the Processor isn't getting enough power, so the computer will not turn on. (Processor isn't turning on)
Why?
1) Just because that Power Supply is new, doesn't mean it is good.
Sometimes you get a bad one. Test the three main voltages coming out, with a multimeter set to DC Voltage.
Need guidance post back in a Comment.
(An economical multimeter can be purchased, for as little as $8 to $12. I have seen cheaper. Available in a multitude of stores. An auto parts store is but one example )
2) You don't have the 4-pin ATX +12 Volt power cable plugged in.
Goes to the white square 4-socket hole connector, to the left top corner of the Processor socket.
(Motherboard installed in computer case)
3) REQUIRES -> TWO 6-pin PCI-Express power cables, for the Nvidia GTX560Ti graphics card.
The Antec HCG750 PSU has 4 of them, so no problem there, IF you have two of them plugged into the graphics card.
Both connectors of the 20 + 4-pin ATX main power cable's connector, need to be used. Biostar mobo requires a 24-pin ATX main power cable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
Post back in a Comment as to power cables plugged in, and DC Voltage test on PSU.
Regards,
joecoolvette
Aug 06, 2012 | Biostar G31-M7 TE Motherboard
FOXCONN MOTHERBOARD UYD761904374 PC661M04 MX 6L Will NVIDIA GeForce 9300 GE graphic card work with Foxconn motherboard UYD761904374 PC661M04 MX 6L. Please help me. I want to install windows 7 and use...
System Ram doesn't count for Gpu ram so 2 gig Ram and 2 gig Gpu will be fine .. check also Psu some Gpu are hungry for power Mine is Gtx770 8 pin + 8pin at 240watts.. hence 750 watt Flower power Psu...
Jul 01, 2017 | ASUS Computers & Internet
When cold starting, my comp will run for a few
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
May 13, 2010 | BFG Technologies NVIDIA GeForce 9800 GT,, ...
Hi I use the Gforce 8600 gts and when ever i try to talk on ventrillio i get all these blocks all over my screen then it turns into a million little ones till i can not see anything i have to resatrt my...
Its a GPU problem.
When rendering high image resolution, this normally
happens on all application, which are VideoRam hunger.
4. Remove the pin.
5. Switch on ur PC.
9. Switch it off.
11. Power on ur PC.
thats all.
Clarifications:
May 08, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
I have vertical red lines generated by my Nvidia 8800 GTS graphics card
Its a GPU problem.
4. Remove the pin.
5. Switch on ur PC.
9. Switch it off.
11. Power on ur PC.
thats all.
Clarifications:
Feb 22, 2010 | ASUS NVIDIA GeForce 8800 GTS (512 MB) PCI...
I am doing animation so maya is 3d software.so its need graphic card.and i have 2gb ram intel core2 duo cpu,e7200 @2.53GHz. and i have 160 gb hard disk.ok.and when i am playing high graphic games then my...
There are several reasons for hardware hangup.
But, if there is a problem with nVIDIA PCI express card, then the problem could be with the GPU.
4. Remove the pin.
5. Switch on ur PC.
9. Switch it off.
11. Power on ur PC.
thats all.
Clarifications:
Feb 21, 2010 | ASUS NVIDIA GeForce 9400 GT,, PCI Express...
When i turn the xbox on the screen on the televison is black. Nothing is showing up.
It's not your TV or your a/v cables or your mind playing tricks on you.
The Problem is 2-3 pins under the G.P.U . called the (video feed line)
to the HANA / ANA chip set have de-solder itself from the main board.
Fix 1 is to have the G.P.U. re-flowed. This gives the most durable repair
Fix 2 is to send it to Microsoft . wait 2-3 weeks. results will very.
Fix 3 Bite the bullet . Open it up remove the G.P.U. xclamp bracket
replace with screws and nylon washers and follow xclamp
mod overheating instrutions . this will get your unit working
it will last anywhere from 1-5 months some times longer.
if you have any questions just comment and ill respond.
Rob
Oct 09, 2009 | Microsoft Xbox 360 Console
Nvidia geforce 9500 gt gpu work on asus p5n73-am
Hi!
Nahh...you can use that gpu with that mobo, but i wouldent recomend it. The GPU - Requires NVIDIA HybridPower™- enabled motherboard, and that mobo dosent have that. It might work but you cant use the full power of that gpu on that mobo. And beside that, that gpu is bigger then the mobo itself
I sugest you to buy another mobo, the gpu you looking at is a good one but your mobo isent that good.
Here is the spec for the GPU:
http://www.nvidia.com/object/product_geforce_9500gt_us.html
And here are the spec for that mobo:
http://shopping.msn.com/specs/asus-p5n73-am-motherboard-micro-atx-geforce-7050/itemid1060345734/?itemtext=itemname:asus-p5n73-am-motherboard-micro-atx-geforce-7050&fulldesc=1
Good luck
Nic
Mar 03, 2009 | Computers & Internet
Audigy 2zs
u need a 2or 3 pin spdif cable from the spdif on ur gpu to the spdif on ur mobo/soundcard. check manuals of ur gpu and mobo/soundcard for correct pin diagrams. dvi wont carry audio even if using HDMI adaptor, u need to ling the gpu to soundcard/mobo depending on what u use for sound.good luck
google "nvidia spdif to soundcard cables"
Jul 14, 2008 | Creative Labs Audigy Gamer Sound Card
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
