Question about Garmin nuvi 260W GPS Receiver
My garmin cannot start - Garmin nuvi 260W GPS Receiver
  • mariocouthin Apr 12, 2009
    I tried the solution but the garmin 260 does not come on .please help
  • 285 Answers
Hi there... If you mean it doesn't do anything when you push/slide the on button, then try this... (mine did the same thing just yesterday and was a result of a very low battery - would not even start with 12v cord in from the car!)...
Find the USB cable that came with your Garmin. Hook the USB cable to your computer, with the other end hooking up to your Garmin (where the normal car cable goes).
The Garmin will probably turn on instantly once you have hooked it up to your PC (assuming the PC is turned on and in Windows etc). This will actually charge the Garmin battery too while hooked up the PC, so leave it connected for a little while (a couple of hours).
If it doesnt switch on automatically when connected to the PC, try using the slide ON switch. Once it is active, it will be in PC transfer mode (assuming you have an SD card in the card slot of the Garmin). Now is a good time to use the Garmin WebUpdate application (available from www.garmin.com) to see if any software updates are available for your unit. If so, go ahead and install them. I updated mine yesterday!
Once you get it working via connection to the PC and the battery has charged up a little, take it back to the car and keep the 12v car cable plugged in all the time. This will continue to charge it up as it is being used (while the car is running of course). You should find that after u get it working on the PC it will again work in the car too...
i think it just turns it off for some reason permanently when it gets a really low/dead battery and only the PC hookup seems to re-activate it... Also, apparently you can hold the slide switch on the Garmin in the ON position for 7 seconds to reset the unit, but that didn't work for me... Worth a try anyway!
Posted on Mar 25, 2009
Garmin Forerunner 305 will not upload to Garmin connect, an error message says "object error"??
Try uninstalling and reinstalling the Garmin Communicator Plugin.
http://connect.garmin.com/help/start/usb
Also, you can call Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 04, 2011 | Garmin Forerunner 305 GPS Receiver
When turning on the unit, it starts up with the Ga...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Start up problem
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 22, 2010 | Garmin nuvi 1300 Car GPS Receiver
Unit locks up after start up and has to be re-set - it doaes this every day when I set off.
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Mar 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
Lost maps for Garmin Nuvi 750
If they are truly gone you'll have to buy them from Garmin. I would suggest to buy the Life Time update. That's what I did. Maybe it's just a software issue?? Get the free WEBUPDATER from Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Jan 18, 2010 | Garmin nuvi 750 GPS Receiver
I got a Garmin 1300 for Christmas; when it is powered up, i get the Garmin name, then a green line begins from the left to start, Stops about one inch in and stops. It powers down and goes black. Help!
I hope that helps.
Jan 16, 2010 | Garmin nuvi 1300 Car GPS Receiver
Where can I get free updates for my Garmin NUVI 250
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} No free maps: but to update software do this:
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Dec 20, 2009 | Garmin nuvi 250W GPS Receiver
Can't communicate between Garmin Nuvi and computer? Get an error message that says some devices have been found but none contain the necessary...
You must use the newest Software (free) from Garmin.
Start with the newest program for YOUR computer BEFORE you plug in your Garmin:
Nov 20, 2009 | Garmin nuvi 200W GPS Receiver
We bought a new garmin 705 and the speed records but not the distance or other features
The Garmin Edge requires that you press the start/stop button to record any data.
1. Before you start riding, press the start/stop button to begin recording.
2. Once you have finished riding, press start/stop button to end recording.
3. Create an account on connect.garmin.com and plug your unit in using the supplied USB cable and download your ride to view details on your cycling session.
Aug 14, 2009 | Garmin Edge 705 Handheld GPS Receiver
How do we update our garmin nuvi 255
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can get that FREE at Garmin here:
First you have to set up an account at Garmin using the serial number on your GPS. Once you do that you can download firmware update for free.
By the way, the correct Garmin approved power OR download cables are a must!!
Jul 14, 2009 | Garmin Nuvi 255 Car GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
393 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
