Question about RCA F27628 27" TV
RCA TV My RCA TV had a red color to the picture when I first got it now it has just a black screen with a red dot in the middle. What should I do?
    Scholar:
  • 47 Answers
Could you supply me with the chasis number from the back of the tv E>G ctc203 at113. With this information , I can tell you probably what the problem is and approximately how much it will cost to repair. Each Rca has its own set of problems. Recently RCA/GE were purchased by a large Chinese Corporation. Some of the newer sets are totally CHINESE.Here are some of the common problems that would give you this symptom. Bad connections on the IHVY(flyback). Open horizontal windings in the Yoke. The original problem is problably due to an inaccaure setting in either the red cutoff or red background. These adjustments can only be made from the servicemans menu and are not accessable to the consumer. The problems described are of a serious nature(except you original one). You may consider shopping for a new set , replacing it with an LCD. The LCD gives off no radiation and cost much less to operate (electricty) Scrivitron
Posted on Jun 18, 2007
F31672et rca tv
Is this a projection/plasma/CRT?
Oct 03, 2008 | RCA F31672ET TV
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
RCA DLP TV with a red dot in the middle of the screen
Sounds like the color wheel stopped and re-started. It may continue to function for a while, but could fail at any time.
I've also seen on rare occasion, a defect in a lamp produce uneven color rendition, but its far more likely that the culprit is the color wheel.
michtech
Feb 13, 2009 | RCA D52W19 52" Rear Projection Television
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
Color problem
i dont know if this will help , but i bought a rca and a month later i had a big green spot in the middle of the screen, the tv repairman replaced one of the three color modules
Oct 20, 2007 | Televison & Video
56 projection t.v. color problems
If you mean they are separated like a 3-D effect, then you have the typical bad convergence IC problem. There are two IC's mounted on a large metal heatsink, they will have STK392-###, the ### being differant models of TV sets. these are soldered into place and are no usually replaced by the user, unless you have solid state repair experience, knowe how to solder, have a schematic on the set, and know the High voltage safty factors of projection TV serviceing. If you have no experience, please play it safe, and get someone who is trained to service TV sets. Good Luck Please do not forget to rate this thread.
Dec 08, 2006 | RCA P52926 52" Rear Projection Television
RCA F27628 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
