Question about SanDisk Sansa e200 MP3 Player
Disconnected When i Charge my snsa up on the computer and then take the usb out it says disconnected but then freezes on that all day and uses up all the battery?
  • 85 Answers
You are going to have to reboot it. It is something that you can do yourself with your manual or send it in to my company. We can get it back and running for under $35. We can try and walk you through it, but I am not sure if you will need firewire or not. thank you, Connie
Posted on Jun 19, 2007
SOURCE:
Nexus 7 problems
Pop the back cover off. It's real easy - you can use a credit card or even your fingernails. Carefully prise all around the edges. It'll come off quite easily. Looking from the rear with USB port at the bottom, you'll see the left side if the unit is occupied by a large rectangular battery. At the top right of the battery is a connector with six wires. Gently disconnect the connector from the main board. Leave disconnected for about 30-60 seconds and then plug it back in.
Put the back cover back on, and then plug in the charger.
You Nexus will charge fine.
Jul 16, 2014 | Google Nexus 7
Netgear WN111V2 adapter disconnected
you may have to reset the wireless network and the computer and restart the network first then the computer
Jan 27, 2014 | NetGear : WG111 54 Mbps Wireless USB 2.0...
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
My passport 5oo Gig freezes my computer
Yes there is. Please note that removing the drive from your external will likely void any warranty you may have with the manufacturer.
If ok with that, remove the drive from the enclosure very carefully. Then connect the internal drive directly to a SATA connector, do not use USB and see if able to access drive. If so, backup data right away.
If this model is only USB connector, or if still not accessible when connected to SATA, then you will need a reputable data recovery service provider.
Feb 15, 2018 | Western Digital Passport WDXML800UE...
Lacie 750 GB External hard drive
Dear,
Please check your BIOS setting. Make sure that Boot from USB device/drive is disable.
Reply....
Regards,
Rakesh Kumar
Mar 31, 2009 | Computers & Internet
Ipodnano8GB connection
you have to restart your iPod. press the middle/center button and the menu button for a few minutes
Jan 01, 2009 | Apple iPod nano
Nuvi 610 - External charging causes screen to freeze.
Don't disconnect it just because the screen freezes. This can happen if the battery is depleted too far, because the load is too great for charging AND running the device simultaneously. Leave it connected for 20 minutes or so, to see if the screen returns to normal appearance. If not, then you will be needing a new battery. Be sure to charge the new one BEFORE it is fully depleted. They are not NiCd batteries, so there is no need to fear ?memory effect". With NiMh and Lithium batteries, those days are gone, thank God!
Mar 30, 2008 | Audio Players & Recorders
Inovix imp-1112 mp3 player problems
Hi. I've had similar problems with the same model.
Have you tried a Firmware re-install yet? If not, do that first using the CD supplied with it.
Whilst it's plugged into your USB port, it'll hopefully also get a bit of a charge.  I notice on mine that the player will only charge from the USB port when the side on/off switch is in the 'on' (up) position, although there are times when the computer will 'reject' the player with the switch in this position - a series of 'ding-dongs' as it connects and disconnects from the USB port!
If this happens to you, just keep trying!  Come back to it each day, and try another Firmware re-load!
Mine took a few days, but then decided to come to life - weird machine!
Sep 23, 2007 | Inovix iMP-20 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
