Whirpool LXR9245E washer question
My washer agitates but willl not drain and spin. There is a hum when the agitator is complete but after around 5 seconds the hum stops (sounds like a circuit shuts it off). What could be causing the washer not to spin and drain. Thanks
  • 15,935 Answers
A blocked pump impeller is the likely suspect.
Remove the hoses and inspect for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Jun 20, 2009 | Kenmore 22422 Top Load Washer
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Jan 15, 2009 | Roper RAX4233PQ Top Load Washer
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
1975 whirpool washer
This problem is usually caused by the wig-wag not functioning. There are ele celinoids on it and they go bad. If the washer agitates properly but you just dont get the spin cycle, its probably the wig-wag. You can look up the part on sears parts site and see if it is still available or obsolete.
Mar 31, 2008 | Kenmore 2303x Top Load Washer
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
