Question about HP Pavilion dv1000 Notebook
My HP Pavilion not started (no power)
When I was browsing internet thru wireless due to low battery I just flugged the power cable and I heard some noise, then the laptop is off. No power. What will be the problem?
  • 520 Answers
Incorrect shutdown with low battery will always cause problems....
first of all youre gonna have to put some charge into the battery...
then..press the power button to startup and wait for activity...lights , sounds etc..then press and hold power button until you hear pc shutdown.then restart...you may have to choose startup in option screen like start with last good config etc but now it will be back on.
Posted on Feb 15, 2009
I have a hp pavilion a1140n and i cant set up wireless internet in my house what do i do
To have wireless internet you would need a (cable or DSL modem depending upon your ISP. A wireless router (doesn't matter which brand) Also for a desktop computer you will need to buy and install a wireless NIC (network interface card) as desktops almost never come with one, only a hardwired NIC (cabled)
Dec 16, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
My HP Pavilion Dv 5000 notebook stop working: no power and the power Led is off. I opened it and tested the power cable which is OK; I checked all over the motherboard looking for some damaged or burnt...
Of the two LEDs at the left front of the notebook, if the left-most one is blinking, then the notebook is in standby. If the left-most one is off and the one to the right of it is blinking, then the notebook is in a low battery condition and quite likely the notebook had initiated hibernation. If you had the AC adapter plugged-in for some time and the low-battery condition persists, then likely the adapter has failed. Normally you would just press the power button to restore from hibernation but if the system had initiated hibernation due to a critical low-battery condition, the system may not respond unless you have inserted a fully-charged battery pack. Here is an excerpt from page 38 (Chapter 3 Power) of the HP Pavilion DV5000 User Manual....
*If the system initiated hibernation because of a critical low-battery condition, connect external power or insert a
charged battery pack before you press the power button. (The system may not respond if the discharged battery pack
is the only power source.)
Jul 27, 2011 | HP Pavilion dv4000 Notebook
I have a hp lap top with wireless internet. It says that it is connected and i try to get on the internet and the gives me a error message. what do i do??
From what you have told us I would unplug and replug in your telephone or cable modem then your wireless router in that order.
If it still dosent work then try the repair internet connection under network troubleshooter on your laptop.
If that doesn't work delete the connection you are having trouble with (on the computer), reboot the computer and rediscover the wireless router/access point and see if that gets it.
Best I can due with limited info. hope it helps.
Oct 24, 2009 | HP Pavilion dv9000z Notebook
I have wireless internet but I can't get any signal on a unsecured network is their another antennai can buy or I heard about a wireless card that plugs into your computer but its expensive . I already...
most laptops turn off wireless to optimise battery life if it is not being used, check in preferences and see if you can turn it on. How far are you from the kit?
Oct 01, 2009 | HP Pavilion dv8000t Notebook
Internet/network problems
Connecting the laptop to your network using a network cable, does this solve your Internet problems?
Does this works without the Internet connection dropping out?
If the wireless connection has a low signal, try positioning the wireless router or the laptop to get a better signal strength.
Also try reinstalling your wireless driver.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Unable to connnect wirelessly thru gprs phone.
You need to connect first one system with the phone. have the proper software of the phone installed on the system and your system should detect it as a modem. you may need to contact your network provider for assistance. Once you have establish a connection on the first sytem and it culd browse, that is the time that you need to create an ad hoc under create a new connection. once you have established an ad hoc, let your other system detect it wirelessly and try to connect to it.
By the way GPRS is similar to dial up so if you have 2 systems online it is just like splitting your 56k connection speed and it could give you no browse at times.
Hope this helps...
Jul 24, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Connection problem with wireless computer.
try connecting your dsl modem to the router and connect another cable between router and the computer
make a wired connection
try browsing
if you can let me know we can connect to your system remotely and can fix any issue you r facing with it
Jun 07, 2008 | HP Pavilion dv6000z Notebook
Internet problem
well..if you can see the router, then it's between the router and the internet..can we assume the router is plugged into the internet feed?
May 01, 2008 | HP Pavilion dv4000 Notebook
No internet on HP Pavilion Notebook
The first thing I would try is a USB wireless adapter. If this works it may be a hardware problem. If this does not work it is likely a software problem. Make sure the interfaces are not disabled in the connections window. Make sure you are using a good cable, test it elsewhere.
May 01, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
