Question about Viper Security and Remote Start System (basic install included)
Mitsubishi lancer alarm and remote starter. How to disarm?
I have Mitsubishi Lancer 2007 with preinstalled alarm/keyless entry. It is not original. It has 1x6pin connector used for door lock/unlock and 1x12pin with other inputs/outputs. Some of them are not used. Also on the side 1x2pin and 1x3pin unused connectors.I need to know wich of them and how to use for disarming/rearming by remote starter module wich has negative output for this.
Please help!
  • 2 more comments
  • itm_c Apr 02, 2009
    I have picture of it. I can send it to your e-mail.
    Were I can send it to?
    Sent from
    Thank you
  • scrtcell May 11, 2010
    Is there a name on the alarm brain if not look on the brain to see if you see a "FCC ID NUMBER"
  • 43 Answers
Ok do that i will see what i can do
Posted on Apr 02, 2009
Keyless remote wont work
Many times if you purchase a used vehicle, the car lot only provides the key because they do not want to spend the money to purchase a key fob. A 2006 Lancer either has a 2 or 3 button keyless entry remote which you can find here:
Keyless Entry Remote Fob Replacement
Feb 08, 2014 | Mitsubishi Cars & Trucks
Want to disarm central locking horn alarm for 2002 lancer glxi
take the wire off the battery that goes to the alarm.
Jan 31, 2011 | 2002 Mitsubishi Lancer
2007 hyunadai sonata which orange wire in kick
More than likely it is going to be the smaller of the two, your best bet is going to be to get a multimeter and touch ground and that orange wire. If the meter reads high resistance when the alarm is on and no resistance when the alarm is disarmed than that is your wire.
Oct 11, 2009 | Remote Starter with Keyless Entry
DO all 06 mizsubishi lancers have keyless remote
Hi, unfortunately there are a few of them that do not have the keyless entry function.
Sep 29, 2009 | 2006 Mitsubishi Lancer
Remote not working how to manually disarm alarm
did you get a different key for your alarm box if not thy the ignition key. joe
Nov 21, 2008 | 2002 Mitsubishi Lancer
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
957 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
