Question about DEI Python 1400XP Remote Start/Keyless Entry System
Trying to find an affordable replacement key fob for the 1400xp.
Original ones broken. Circuit City ask $45.00.
  • 112 Answers
Thats a good price... never seen em cheaper than $40 programmed, you might find cheaper online, but then you need to program it..
Posted on Jan 26, 2009
  • 1,602 Answers
CALL THE VENTER OF THE DEVICE AND THEY ARE WILLING TO SALE IT TO YOU
OR
FIND A COMPANY THAT INSTALL THAT BRAND OF PRODUCT AND GO SEE THEM OR CALL THEM
Posted on Feb 19, 2009
  • ROD GANDY Feb 19, 2009
    OPEN THE HOOD AND SEE IF YOU CAN SEE WHO MANUFACTURE THE PRODUCT
    GO ONLINE AND TYPE THE FOLLOWING
    MANUFACTURES NAME, MAKE, AND IF HAS MODEL#
    ENTER
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a viper 7701 remote that just stopped working. Battery is new. Do I have to re program something
If it is the OE (original equipment) key fob, meaning if it is the alarm remote control that came with the original purchase of the car it should not need reprogramming. If it is an aftermarket alarm then it may need reprogramming, more information is required to answer the question.
This is a common issue and the most common problem is that the solder joints holding the battery in the proper location. If any of these are broken the remote will not function. It can be fixed with a little solder or if your uncomfortable with doing it yourself, take it to a computer repair store (they can fix it ONLY if you have a broken solder point).
Take the key fob to the closest auto parts store (aka. autozone, o'reilly's, advance) and near the counters they have a key fob testing equipment (FREE). If the remote is working a light will blink when you push the key fob button while close to the testing equipment. If the testing light shows that the fob is working but does NOT unlock your doors, it needs reprogrammed. If the testing light doesn't blink at all, repair or replacement of the key fob is indicated.
Hope this helps and good luck!
Dec 31, 2014 | 7701V Remote for Viper Responder SST Car...
My original key fobs quit working on my 2005 GMC Yukon SLT. I changed the batteries with no positive result. I next replaced the key fobs and followed the programming. This worked for a couple of months...
The keyless entry system has the following main components:
• The transmitters
• The passenger door module (PDM)
The PDM communicates with the body control module (BCM) through the keyless entry serial data circuit. When you press a button on a transmitter, the transmitter sends a signal to the PDM. The PDM sends a request to the BCM and the BCM performs the appropriate function.
Jul 20, 2017 | 2005 GMC Yukon
Python 1400xp installed by circuit city on a 2004 chevy monte carlo. The car works fine but every now and then the car will not start with the remote or with the key, it takes 10- 30 mins to finally...
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
Sep 15, 2017 | DEI Python 1400XP Remote Start/Keyless...
Jeep liberty remote issue
the fob does come apart ( to replace the battery and the workings will come out and fit in the new key fob
Aug 23, 2017 | Jeep 1:10 Remote Controled Monster Liberty...
I have a 2005 Jeep Grand Cherokee with the original key fobs. Arrived back to the vehicle and the keys are not working to unlock/lock the car. Mannually unlocked, and the car thinks I am trying to steal...
The key fobs have failed take to the dealer they would have to replace the key fobs don't try to start it more then 3 time or it will lock out for 1 hour.
Oct 25, 2009 | 2005 Jeep Grand Cherokee
Front door locks on a 99 passat
You have the wrong KEY if it won't turn any locks.
You can use the KEY fob from another Passat.
The one you have was most likey not the original
and the car was reprogrammed to except that FOB.
The Fuse panel Is inside the DRIVES side.
Open the Driver door. Look at the side of the DAShboard.
THat Giant "B" Shapped plastic cover pops off.
Check the fuses...IF any are broken,black or no good.
REplace them
Hope this helps
Sketchlab.com
MugShot Collection.
May 11, 2009 | 1999 Volkswagen Passat
Security light always on, alarm won't chirp, not working
Do you have a toggle switch or button in the system ? If you do put the ignition key in the ON postion and switch toggle in opposite direction. It might now be in the VALET mode
Mar 26, 2009 | DEI Python 1400XP Remote Start/Keyless...
2005 Durango 2 broken key fobs
No I am trying to help go to my webiste and i will download the factory spec and how to reset it for you ok collisionrepairadvice.com
Mar 09, 2009 | 2002 Jaguar X-Type
Circuit City installed Python 1400XP on my 2002 Suburban.
That does not sound intierly tru but what is the year ,make and model of your car and i can check for you. but if memory seves me right it just consists of alot of extra work that most tech's dont like to do.
Nov 14, 2008 | DEI Python 1400XP Remote Start/Keyless...
Open Questions:
See all DEI Python 1400XP Remote Start/Keyless Entry Questions
DEI Python 1400XP Remote Start/Keyless Entry System Logo
235 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
