Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
Cannot stop my hard drive in the safely remove hardware window
  • dax_702 Feb 26, 2009
    Turns out windows media player was set to index this drive for pictures... Not sure how that happened but it's finally fixed. Thanks again.
  • 298 Answers
You probably have Indexing turned on or AVirus scan running (or someone is on your box remotely....)
Something or someone is tying up the drive.
Turn off indexing: Rt click Drive, Properties, and UNCheck 'Allow windows (or indexing service) to index this drive
Stop the AVir Scan:
RtClick AVIRus icon in taskbar, click stop - or Press CNTL-ALT-DEL, processes, locate your AVir proggie, Rt click and select end process tree
See whos messing with you: Goto DOS, Type Net Users
Posted on Jan 17, 2009
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
16gb pendrive
Which operating system ?
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer.
This prevents data loss and extends the life of your external storage device.
Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive.
This is necessary for the device to be removed properly.
Don't forget to save your files before closing the files.
Right-click the "USB" icon marked with a checkmark.
It is located on the bottom right of your taskbar.
From the pop-up menu, click "Safely Remove Hardware."
A small window will be displayed.
Select the USB flash drive you want to unplug then click the "Stop" button.
A confirmation window will appear. Click the appropriate hardware device, then click "OK."
The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer.
Click "OK," then click "Close."
or
Click start all programs accessories windows explorer navigate to your usb drive right click on it select remove or exit.
Jul 27, 2013 | SanDisk Computers & Internet
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Message displays when attempting to "safely remove hardware"
You need to go to the Tool Bar, (bottom r/h side), and click on Safely Remove USB hardware. and choose your device and shut it down from here then remove.
Jan 29, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I want to eject Have Cruzer Titanium 2.0 USB memory plugged into computer. No programs or files from it are currently in use. After clicking on Safely Remove hardware, the message Problem Ejecting USB Mass...
Make sure you have all programs and folders closed. Then try stopping usb mass storage, there should be more then one option so try removing the drive itself on the list. If that doesn't work. I myself would probably just restart the computer. Then try again.
Thanks,
Lee
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cannot stop the device
power off your pc remove the hard drive power back on .
window may come on is safe mode that good let safe mode run when dont reboot pc it will come back to normal
Aug 05, 2009 | Computers & Internet
WD Passport Portable Hard Drive 120 GB Problem saftly removing hardware. Receive the message 'h device ' Generic volume' canot be stopped right now. Try stoping the device again later.
well i cannot actually figure out your problem well all windowsxp and windows vista allows you to safely remove your usb device well wats the error like diid you check microsoft for lates updates and patches !!try it oderwise tell me the exact error or problem!!thanx
Jan 31, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Sometimes this can happen with Generic Drivers.
Make sure you installed any drivers that came with the device, and if they didn't come with any try going to the Manufactures website and downloading the drivers.
Jan 02, 2008 | Western Digital My Book Essential Edition...
Where is my "safely remove hardware" icon in Windows XP?
b938e76.jpg plz double click on the symbol to right hand side bottom.and stop the device.and then u can safely remove the device.
Oct 27, 2007 | Buffalo Technology 250GB USB SATA 2.0 HD...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
99 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
