We smell gas leaking when baking with the oven.
SOURCE: GE Profile gas range - Model Number removed by
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
SOURCE: GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
SOURCE: gas oven won't work on "bake" setting
If the hot surface ignitor is very red in the middle of it when turnig on the oven, it is faulty. Replace it.
SOURCE: MY GE PROFILE RANGE OVEN
I have the same problem and GE has a technical memo out on this. It requires a programming change. Right now, I am trying to get GE to fix it at no charge, but so far, no luck.
SOURCE: I have a GE Spectra
Something has been spilled down the vent from the top....when the oven gets hot it is burning out and causes the smkoe...
On a nice day when you can open the windows, turn the oven on at the highest setting... like 550....then let it go till the smoke stops....this will burn off whatever is causing the smoke....
There is no filters for that type of thing...if you have a vent fan over the stove you can run that to help filter or exhaust the smell...
heatman101
