Question about HP Officejet 6310 All-In-One InkJet Printer
Copy problem hp 6310 all-in-one
Hello, I have an HP all-in-one 6310; my problem is with the copy part; after i put the paper in, on the feeder or into the scanner unit, i push the copy button, i puch ok when asked for the number of copyes and nothing, but nothing happens. No messages, nothing. I have full cartriges, paper and stuff, it prints ok but never copyes.Pleas help.
    Problem Solver:
  • 10 Answers
Instead of pushing the Ok button you should push the "Start Copy - Black" or "Start Copy - Color".
Posted on Aug 27, 2009
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Envelopes won't feed into my hp 6310 all in one. What can I do?
Hello db,
Try this...Place the envelope to the right side of the feeder. Position the envelope with the flap facing up and to the left. I use Microsoft Office Word software for feeding and printing envelopes with good results. You can also go to the HP website and download their envelope printing software for free.
Hope this is helpful for you. If it is, please leave positive feedback for me. Good luck! NormanZ
Jul 11, 2009 | HP Officejet 6310 All-In-One InkJet...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Roller part broken - Throw it away or can it be repaired
hp do spares contact them . or look on ebay for same model spare and repairs. you might get one cheap.
Mar 26, 2009 | HP Officejet 6310 All-In-One InkJet...
At scaning time show
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
6310 has a fine black line down the entire length of the page
Need the clean the pinch rollers on the top of the unit. Use a small amout of alcohol on a piece of paper towel. Clean all the pinch rollers and then let unit sit for about 15 to 30 minutes.
Feb 18, 2009 | HP Officejet 6310 All-In-One InkJet...
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 officejet
Open the document feeder by pulling straight up and look for an obstruction.
Jan 06, 2009 | HP Officejet 6310 All-In-One InkJet...
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
148 people viewed this question
Ben Johnson
