Question about Canon MX300 Office All-In-One Printer
Canon MX300 Paper Jam
I'm new to this business and a friend of mine has a Canon MX300 printer which keeps on reporting a paper jam message. Initially, a paper had jammed inside and they just pulled it out but now it keeps saying paper jam even after we opened and cleaned the inside. How can I clear this error messaged?
  • trepani4 Feb 22, 2009
    I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Posted on Jan 09, 2011
Buy a new printer - ( my one shows paper Jam Cannon MX 300 ) even with out a paper jam.
Posted on Jan 20, 2012
PRINTER SAYS IT IS JAMMED I SEE NO PAPER IN IT
Posted on Oct 24, 2012
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper jam
Check the inside of the machine, and try unplugging the power cord for ten minutes first.
Sep 11, 2008 | Canon MX300 Office All-In-One Printer
Morning, Im working with a Canon All-In-One Inkjet MX300 printer. It is not allowing me to print as it keeps telling me I do not have paper loaded in the printer. I have turned it off, and back on. Even...
Hi....hard time with your Canon... It possible you have a paper jam inside you unit.. at the back you will see a endle in both side take off the tray and look for paper jam., also check where you feed the paper if you don't have anything like paper clip pencil jam it inside the feeder
Oct 16, 2010 | Canon MX300 Office All-In-One Printer
Canon Pixma MX300 printer had a paper jam. I took out the paper, and it was all there with no missing parts. It continues to say there is a paper jam - there appears to be no reason for the jam. I...
Try checking that a foreign object is in the paper feed rollers- do this by inserting a thin piece of plastic about 2 cm wide through the rollers from the paper exit side. Plastic like that from a shirt box (about 2cm wide by 20 cm long and 1 mm thick works well. I have solved this problem many times with my mx300 and it clears out objects which have droppped into the paper feed, such as Pens , yes pens. and paper clips etc which are otherwise hard to detect on this printer.
Sep 25, 2010 | Canon PIXMA MX300 All-in-One Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon MX300 Paper Jam alarm
hi I'm 30 eyars old from sudanes girl ilove sexy girl&woman
May 31, 2009 | Canon MX300 Office All-In-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon MX300 printer shows jam and no paper in
I got hold of Canon support & he had me give him a # behind the white ribbon inside & after that he asked when purchased (7-28-08) Now I will be getting a new unit and have to send back old one at NO cost to me. Who knows???? Was happy with the outcome & surprised!
Nov 16, 2008 | Canon PIXMA MX300 All-in-One Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Canon MX300 Office All-In-One Printer Logo
2,459 people viewed this question
old marine
old marine
