Question about PC Connection Cross-Over Cable (363003X)
Switch to switch connection
I am having a network of 5 pcs in one room with d link 8 port switch, and in another room 4 computer lan using another switch. now i want to connect both the switch using cat5 cable. i want cable pattern or colour code for connecting switches
Sir mujhe 2 swich add karna hai me kya karu kaisi cable banana hai ple aap bataiye
Posted on May 25, 2010
  • yogesh jadhav Mar 21, 2013
    agr 2switch add krna h to cat5 cable use kro or color code:- white-green,green. white-orange, bule. white-bule, orange. white-brown, brown.
In the 1st end of your cat5 cable the color codes are: white orange, orange,white green,blue,white blue,green,white brown,brown and in other end codes are: white green, green, white orange, blue, white blue,orange,white brown,brown....gud luck
Posted on Mar 25, 2009
    New Friend:
I want to colour code switch to switch
Posted on Feb 09, 2013
We have 6 computer in one room and other room 5 computer and one server and i connected both room in two switch but problem is when i tracking system not sho 2 swithc there show one switch what i do now , ther for my system are slow
Posted on Nov 19, 2009
    Scholar:
  • 108 Answers
Crossover cable :
Connector 1 connector 2
1 <-> 3
2 <-> 6
3 <-> 1
6 <-> 2
Color diagram at this address:
http://www.duxcw.com/digest/Howto/network/cable/cable5.htm
Hope this helps.
Posted on Jan 17, 2009
I have small network in an office, with 8 - port Ethernet switch. after buying two new PCs, i have tried to expand the LAN by adding another switch and i couldnt dont know why. i have connected the two...
Sir your computers are not in the same workgroup that's why coundn't ping the computer please open up *my computer then right click in it and go properties then on to the computer name > network id at the right side of that properties then add you network name what ever your have then it will work properly
( Note: do these things on that computers which is connected to the other port)
Thank you
Mar 29, 2012 | D-Link DES-1008D 8-Port Ethernet Switch...
I have 10 computers and 2 printers networked in the office. I'd like to hae them all wired. I bought a 10/100 switch but not sure how to hook it up with my router. Any advice?
Most low to mid range switches require no configuration. Switch-to-router connections use a standard straight-through CAT-5 network cable, same as for your PC. Connect any switch port to any LAN port on the router (you didn't say if your router has more than one) and then connect your PCs and printers to the other switch ports with CAT-5 network cables. The WAN port on the router remains connected to the upstream (Internet) provider.
Feb 19, 2011 | Computers & Internet
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
CONNECTIVITY PROBLEM WITH 8 PORT D-LINK SWITCH FOR MORE THAN 3 PC
First thanking to using d link switch
Tell me Your dns
and using pppoe ya proxy
KETAN PATEL
Mar 11, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Pano mgnetwork?
gud pm keanne...hmmm here's my suggestion:
1st u need to buy 8-Port Hub/Switch
NIC or LAN Card
7 pcs UTP Wire w/ RJ45 Jack on both end (depende sa haba)
Then connect smartbro to the CPU (Built-in LAN)
Connect 8-Port Hub/Switch to the CPU (LAN Card)
Install Hub/Switch Driver (If Needed)
Connect the 6 PC to the Hub/Switch
Setup your network using Network Wizard (Control Panel)
goodluck...
Jan 29, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Calculate network topology cost
Answers as follows
  1. $100 ({n(n-1)}/2)
  2. $50 (n links)
  3. 3 (number of pcs/2)
  4. 1 (in any hub topologyonly one pair would commm. at a time)
  5. Bus ( $40 n-1 links)
With Regards,
TPV
Jan 12, 2008 | Compaq NETELLIGENT 3024 24-PORT 10BASE-T...
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
Open Questions:
See all PC Connection Cross-Over Cable (363003X) Questions
Computers & Internet Logo
3,437 people viewed this question
Top PC Connection Computers & Internet Experts
David Payne
David Payne
Are you a PC Connection Computer and Internet Expert? Answer questions, earn points and help others
