Question about Zenith E44W48LCD 44" Rear Projection HDTV
ZENITH E44W48LCD Ballast
The TV comes on, generates sound, but no pix. some lamp illumination generated. turn off then on a few times and it works. ballast gone bad? if so, where is the assembly?
    President:
  • 3,130 Answers
Could be a bad ballast or light light control circuit. I have also seen a burned or bad socket cause a problem with this set. Good Luck
Posted on Jun 19, 2007
SOURCE:
I have a 2005 zenith 52 inch model# Z52SZ80 heres the problem i replaced the lamp and when you turn it on as soon as the picture comes up the lamp shuts off and the red lamp light blinks 8 times then...
This is a DLP tv wright?Problems with many DLP tvs after changing the tv projection lamp,tvs still have the same problems or make alots of cliking sound too.The board that call the Ballast baord is also is dead.The Ballast board only job is to ignite the tv projection lamp.
Mar 01, 2011 | Zenith Televison & Video
I recently replaced the lamp - part # 915P061010. But the TV powers off about every 20 - 30 minutes / red status lamp is illuminated. At times the TV will remain on for hours. But eventually the TV...
It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
Sep 13, 2010 | Mitsubishi WD-57734 57" HDTV
I have an older 48" LCD projection TV (model E44W48LCD). The lamp light came on so I ordered a replacement bulb and installed it. Now i get no picture or sound. Is there a reset switch I might of missed?...
It sounds like you may have a lamp door interlock problem. I have a tip at http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which tells you how to troubleshoot this problem. Let me know if I can provide any additional help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 29, 2010 | Zenith E44W48LCD 44" Rear Projection HDTV
KF42WE610 bad lamp... and ballast?
DLP Lamp has electrodes inside and ballast generates high voltage that makes spark on these electrodes thus got high bright light. New lamp wont die due to bad ballast so replace lamp and see tv works or not.
This tv has self diagnostic feature, turn On tv and let it shut down, now check standby light that would be blinking in specific order, for example 3 or 4 times blink then pause for 3 seconds and again blinks.
Let me know how many times standby light blinking in this tv to help you with more info.
Thanks.
May 16, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith e44w48lcd Won't turn on
need manuals for model z32Lc2d ser719192169807
Jan 05, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith E44W46LCD 44 in. Rear won't start
The buzzing is the ballast for the lamp trying to light the bulb. From what you've described it is a lamp failure. It's not that hard to change but you'll have to obtain a new lamp first. You can try and buy it from LG (800-243-0000) but I'm not sure if they'll sell to a consumer. Then you have to reset the lamp timer after you replace it. Hold the mute on the remote and the enter button on the tv at the same time for about 8 seconds and a screen will come up asking if you want to reset the timer. Just follow what it says to reset it.
Jan 02, 2008 | Zenith E44W46LCD 44" Rear Projection...
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Zenith E44W48LCD 44" Rear Projection HDTV Logo
192 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
